查看: 3016|回复: 0
HP ZBOOK 15U G2
发表于 2016-3-12 06:22:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
请问各位有谁知道HP笔记本欢乐bios 芯片出现下面这个文字 是怎样的?
谢谢
when we monted everything again and started the computer it said: The embedded controller MUD data is not valid while MPM is locked
so i took away the cmos/bios battery again for about 10-15 minutes.. after this the new bios did a restore.. and allsow collected the password again.. so now we are stuck at the same spot as before..
