查看: 1345|回复: 2
Toshiba L500 la-5322p HDD not detecting
发表于 2015-11-1 17:56:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 阿联酋 来自 阿联酋
customer came this morning with Toshiba l500. Harddisk not detecting.
Checkedcd drive it's led lighten but try not ejecting suspect voltage drop.
Dissembledand checked voltage which is 3.3v and 5v
3.3vok but only 3v on +5vs rail.
Onq30 +5valw ok and 5v on gate but only 3v on source
Triedchange mosfet and got +5vs on source checked with hdd it was ok
发表于 2015-11-1 21:05:14 | 只看该作者 来自: 北京 来自 北京
竟然还有外国友人,英语好的上吧
发表于 2015-11-1 22:20:45 | 只看该作者 来自: 广东广州 来自 广东广州
看来论坛外国友人还是有  但是很少发帖
