查看: 4198|回复: 3
笔记本常用芯片资料---点点就来
发表于 2009-1-9 13:06:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
费了点时间,收集了一些下载网址,资料点点就来.
AAT3200  http://www.analogictech.com/products/digitalfiles/AAT3200.pdf
   AAT3201  http://www.analogictech.com/products/digitalfiles/AAT3201.pdf
   LD0与VLD0的设计原理及性能测试  http://solution.eccn.com/pdf/ce_082011f.pdf
   AAT4626 USB双通道电源开关  http://www.100y.com.tw/pdf_file/ANALOGIC_AAT4626IAS-1-TI.pdf
AAI3680  未查到
AAT4280  http://www.analogictech.com/products/digitalfiles/AAT4280.pdf
AAT4285  http://www.analogictech.com/prod ... T4285_datasheet.pdf
AD1885  http://alsa.cybermirror.org/manuals/ad/AD1885_0.pdf
        http://alsa.cybermirror.org/manuals/ad/AD1885.pdf
AD1888  http://www.analog.com/static/imp ... a_Sheets/AD1888.pdf
AD1981  http://pdf1.alldatasheet.com/dat ... 584/AD/AD1981A.html
ADP3160/ADP3167 http://www.dzjsw.com/jcdl/a/ADP3160.pdf
ADP3166  http://www.datasheetcatalog.org/ ... xiejg8zgczs6ewy.pdf
ADP3168  http://www.datasheetcatalog.org/ ... 281464ADP3168_0.pdf
ADP3170  http://www.datasheetcatalog.org/ ... ices/ADP3170JRU.pdf
ADP3180  http://home.wanadoo.nl/mewannabee/images/ADP3180.pdf
ADP3181  http://media.digikey.com/pdf/Dat ... %20PDFs/ADP3181.pdf
ADP3203  http://www.datasheetcatalog.org/ ... 063802ADP3203_0.pdf
ADP3421  http://www.analog.com/static/imp ... _sheets/ADP3421.pdf
ADP3806  http://www.datasheetcatalog.org/ ... 809848ADP3806_0.pdf
AIC1567  http://www.mcu104.com/download/aic/DS-1567-02.pdf
ALC200   未查到
ALC201A  未查到
ALC655  ftp://152.104.238.19/pc/audio/ALC655_DataSheet_1.3.pdf
        http://realtek.info/pdf/alc655.pdf
AMS1505  http://www.advanced-monolithic.com/pdf/ds1505.pdf
APA2020  http://www.icwic.cn/icwic/data/p ... lifier/a/512077.pdf
TPA0202  http://focus.ti.com/lit/ds/symlink/tpa0202.pdf
APW7060  http://www.datasheetcatalog.org/datasheets2/18/183718_1.pdf
bq2040  http://focus.ti.com/lit/ds/symlink/bq2040.pdf
BQ2060  http://www.datasheetcatalog.org/ ... truments/bq2060.pdf
bq24700/01 http://focus.ti.com.cn/cn/lit/ug/sluu097/sluu097.pdf
           http://www.datasheetcatalog.org/datasheets2/52/527409_1.pdf
bq24702/03 http://focus.ti.com.cn/cn/lit/ug/sluu160a/sluu160a.pdf
           http://www.datasheetcatalog.org/ ... 7dilqx12gpixwfy.pdf
CM8501/A  http://www.championmicro.com.tw/ ... 20Device/CM8501.pdf
CM8562  http://www.champion-micro.com/layout%20guide/CM8562-layout.pdf
        http://www.osea.com.cn/down/1219473686_1.pdf
CMI9738
CS5322  http://www.intusoft.com/onsemipdfs/cs5322.rev6.pdf
CS5308  http://www.aeng.com/articles/CS5308.pdf
CS950502  未查到
ICS950508  http://pdf1.alldatasheet.com/dat ... ICST/ICS950508.html
CY28404  http://pdf1.alldatasheet.com/dat ... YPRESS/CY28404.html
DS1620  http://pdfserv.maxim-ic.com/en/ds/DS1620.pdf
DS2770  http://ibutton.ru/pdf/Dallas_Sem/bat/DS2770.pdf
        http://www.eetkorea.com/ARTICLES ... DF?SOURCES=DOWNLOAD
DS2770K http://www.ed-china.com/ARTICLES ... DF?SOURCES=DOWNLOAD
FAN5056  http://www.datasheetcatalog.org/ ... ild/FAN5056MV85.pdf
FAN7601  http://www.fairchildsemi.com/ds/FA%2FFAN7601.pdf
FAN7602  http://www.industry.su/FAIRCHILD/PDF/FAN7602.pdf
IPM6220A http://www.intersil.com/data/an/an1005.pdf
         http://www.intersil.com/data/fn/fn9032.pdf
ISL6223  http://www.intersil.com/data/fn/FN9013.pdf
ISL6224  http://www.intersil.com/data/fn/FN9042.pdf
ISL6225  http://www.intersil.com/data/fn/FN9049.pdf
LM4861  http://www.depeca.uah.es/docenci ... sa_it_00/lm4861.pdf
LM4863  http://eshop.engineering.uiowa.edu/NI/pdfs/01/28/DS012881.pdf
LM4880  http://eshop.engineering.uiowa.edu/NI/pdfs/01/23/DS012343.pdf
LM4881  http://www.depeca.uah.es/docenci ... sa_it_00/lm4881.pdf
LM4911  http://www.datasheetcatalog.org/ ... onductor/LM4911.pdf
LT1505  http://www.datasheetcatalog.org/ ... chnology/1505fc.pdf
LTC1628  http://sigma.octopart.com/528397 ... 28IG-SYNC%23PBF.pdf
         http://www.datasheetcatalog.org/ ... hnology/1628sfs.pdf
ITC1709  http://www.datasheetcatalog.org/ ... nology/3728lxfa.pdf
LTC4008  http://sigma.octopart.com/609872 ... TC4008EGN%23PBF.pdf
M51998P/FP  http://documentation.renesas.com ... d0837_m51998pds.pdf
M61040FP  http://www.datasheetcatalog.org/ ... oration/mXtxtrv.pdf
MB3878:   http://www.fujitsu.com/downloads/MICRO/fma/pdf/e427706.pdf
MIC2545A/2549A:   http://server.oersted.dtu.dk/ftp ... ok/pdfs/mic2545.pdf
MIC5205:   http://www.hep.ph.ic.ac.uk/~mn197/Calice/mic_5205ym5_tr.pdf
NCPl205:   http://www.datasheetcatalog.org/ ... uctor/NCP1205-D.PDF
             单端PWM 控制器NCP1205 及其应用  http://www.symcukf.com/DataSheet/035/4.pdf
NCP1207:   http://swordman.blog.dianyuan.com/u/61/1199616751.pdf
             彩电使用实例:   http://www.tv160.net/ic/UploadFiles/200805/2008050120230763.pdf
             AND8127/D:   http://www.datasheetcatalog.org/ ... owfgulx6xjiatky.pdf
NCP5201:   http://www.datasheetcatalog.org/ ... 7t9d4l0pddha9wy.pdf
             http://www.ic-on-line.cn/IOL/datasheet/ncp5201mn_3591834.pdf
NCP5314:   http://www.onsemi.com/pub_link/Collateral/NCP5314-D.PDF
             http://dkc3.digikey.com/Media/PD ... %20PDFs/NCP5314.pdf
NCP5355:   http://www.datasheetcatalog.org/ ... 474oo1s53gfc83y.pdf
OZ960:   http://www.lcd-japan.com/pdf/ds/OZ960_O2MICRO.pdf
SC1470:    http://datasheet.digchip.com/420/420-17701-SC1470.pdf
SC1486:    http://www.semtech.com/pc/downloadDocument.do?id=437
SC2422A:   http://www.revistapcecia.com.br/downloads/datasheets/SC2422a.pdf
SC2616:   http://www.semtech.com/pc/downloadDocument.do?id=451
TPS51020:   http://focus.ti.com/lit/ds/symlink/tps51020.pdf
            http://focus.tij.co.jp/jp/lit/ug/sluu194/sluu194.pdf
            http://focus.tij.co.jp/jp/lit/ml/slyy016a/slyy016a.pdf
TPS54672:   http://www.datasheetcatalog.org/ ... uments/tps54672.pdf
MAX745  http://seniordesign.engr.uidaho.edu/2005_2006/jarhead/MAX745.pdf
MAX785  未查到
MAX786  http://www.datasheetcatalog.org/datasheet/maxim/MAX786.pdf
MAX1522/MAX1523/MAX1524  http://www.dzjsw.com/jcdl/m/MAX1524.pdf
MAX1540/MAX1541  http://www.datasheetcatalog.org/ ... MAX1540-MAX1541.pdf
MAX1630–MAX1635  http://www.datasheetcatalog.org/ ... MAX1630-MAX1635.pdf
MAX1630EVKIT-MAX1632EVKIT  http://www.datasheetcatalog.org/ ... IT-MAX1632EVKIT.pdf
MAX1644  http://www.maxim-ic.com.cn/pdfserv/en/ds/MAX1644.pdf
MAX1644EVKIT  http://www.datasheetcatalog.org/datasheet/maxim/MAX1644EVKIT.pdf
MAX1645B  http://www.datasheetcatalog.org/datasheet/maxim/MAX1645B.pdf
MAX1710/MAX1711/MAX1712  http://www.chipcatalog.com/Doc/B ... AFD75968152D1F7.pdf
MAX1714  http://sigma.octopart.com/96679/datasheet/Maxim-MAX1714AEEP.pdf
MAX1715  http://www.datasheetcatalog.org/datasheet/maxim/MAX1715.pdf
MAX1717  http://www.datasheetcatalog.org/datasheet/maxim/MAX1717.pdf
MAX1718  http://www.datasheetcatalog.org/datasheet/maxim/MAX1718.pdf
MAX1736  http://alignment.hep.brandeis.edu/Electronics/Data/MAX1736.pdf
MAX1772  http://www.farnell.com/datasheets/118202.pdf
MAX1773-MAX1773A  http://www.datasheetcatalog.org/ ... AX1773-MAX1773A.pdf
MAX1773EVKIT  http://www.datasheetcatalog.org/datasheet/maxim/MAX1773EVKIT.pdf
MAX1830/MAX1831 http://pdfserv.maxim-ic.com/en/ds/MAX1830-MAX1831.pdf
MAX1845  http://www.datasheetcatalog.org/datasheet/maxim/MAX1845.pdf
MAX1845EVKIT  http://www.datasheetcatalog.org/datasheet/maxim/MAX1845EVKIT.pdf
MAX1873  http://www.farnell.com/datasheets/97549.pdf
MAX1873EVKIT  http://www.datasheetcatalog.org/datasheet/maxim/MAX1873EVKIT.pdf
MAX1901-MAX1904  http://www.datasheetcatalog.org/ ... MAX1901-MAX1904.pdf
MAX1908/MAX8724  http://www.datasheetcatalog.org/datasheet/maxim/MAX1908.pdf
MAX1909  http://www.datasheetcatalog.org/datasheet/maxim/MAX1909.pdf
max1909evkit  http://www.spezial.de/doc/maxim/max1909evkit.pdf
MAX1992/MAX1993  http://datasheets.maxim-ic.com/en/ds/MAX1992-MAX1993.pdf
MAX1777/MAX1977/MAX1999  http://www.datasheetcatalog.org/ ... MAX1777-MAX1999.pdf
MAX1777/MAX1977/MAX1999EVKIT  http://www.datasheetcatalog.org/datasheet/maxim/MAX1999EVKIT.pdf
MAX8794  http://beta.octopart.com/Maxim__MAX8794ETP%2BT__0.pdf
参与人数 1下载分 +20 收起 理由
liu13403327758 + 20 很方便
发表于 2009-1-9 13:07:32 | 只看该作者 �
有少数几个没有查到, 有此资料的可以补上来.
发表于 2009-3-15 14:46:06 | 只看该作者 �
发表于 2009-3-15 14:48:49 | 只看该作者 �
