查看: 1980|回复: 2
盈通GTS250-512GD3开机发现花屏
发表于 2015-6-9 08:57:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
直接上mats测试的数据,,,显示的是A32-A63有问题
MATS version G98_BETA1.  Testing G92 with 512 MB of memory.
Errors found.  Use .Status() or .PrintErrors() for more info.
This message will only appear once.
   LANE    EB0 READ ERR EB0 WRT ERR  UNKNOWN ERR
FBA[31: 0]           0            0            0
FBA[63:32]           0     30767519            0
FBB[31: 0]           0            0            0
FBB[63:32]           0            0            0
FBC[31: 0]           0            0            0
FBC[63:32]           0            0            0
FBD[31: 0]           0            0            0
FBD[63:32]           0            0            0
External Bank 0 Failing bits:
   A32 A33 A34 A35 A36 A37 A38 A39 A40 A41 A42 A43 A44 A45 A46 A47
   A48 A49 A50 A51 A52 A53 A54 A55 A56 A57 A58 A59 A60 A61 A62 A63
Read    Error Count: 0
Write   Error Count: 30767519
Unknown Error Count: 0
BIT  FRONT WRITE  FRONT READ  UNKNOWN
A32       70056           0           0
A32     6300384           0           0
A32     6302363           0           0
A33      236718           0           0
A33     6311732           0           0
A33     6312610           0           0
A34       45007           0           0
A34     6300337           0           0
A34     6297681           0           0
A35      327517           0           0
A35     6306864           0           0
A35     6309339           0           0
A36       43236           0           0
A36     6302027           0           0
A36     6298555           0           0
A37      163660           0           0
A37     6308097           0           0
A37     6305149           0           0
A38       48477           0           0
A38     6300767           0           0
A38     6295823           0           0
A39      271311           0           0
A39     6311106           0           0
A39     6317764           0           0
A40     6030303           0           0
A40     4868255           0           0
A40      791442           0           0
A40     5997560           0           0
A41     5600875           0           0
A41     4346530           0           0
A41      793899           0           0
A41     4329089           0           0
A42     6026330           0           0
A42     4868773           0           0
A42      794384           0           0
A42     5997385           0           0
A43     5603166           0           0
A43     4347706           0           0
A43      795109           0           0
A43     4328863           0           0
A44     6031894           0           0
A44     4867969           0           0
A44      794842           0           0
A44     5996356           0           0
A45     5600902           0           0
A45     4346552           0           0
A45      796463           0           0
A45     4328144           0           0
A46     6030181           0           0
A46     4867456           0           0
A46      794898           0           0
A46     5995868           0           0
A47     5606392           0           0
A47     4345425           0           0
A47      794705           0           0
A47     5791169           0           0
A48     2114192           0           0
A48     4405142           0           0
A48      264289           0           0
A48     1494759           0           0
A49     5733927           0           0
A49     4244229           0           0
A49      263498           0           0
A49     1496819           0           0
A50     2113132           0           0
A50     4405777           0           0
A50      264546           0           0
A50     1494655           0           0
A51     5733274           0           0
A51     4244305           0           0
A51      264321           0           0
A51     1496617           0           0
A52     2114496           0           0
A52     4406136           0           0
A52      264049           0           0
A52     1494690           0           0
A53     5732312           0           0
A53     4245246           0           0
A53      264103           0           0
A53     1496575           0           0
A54     2113724           0           0
A54     4406091           0           0
A54      262814           0           0
A54     1494980           0           0
A55     5733783           0           0
A55     4244613           0           0
A55      263763           0           0
A55     1496329           0           0
A56     4707728           0           0
A56     6522811           0           0
A56      433039           0           0
A56     6516564           0           0
A57     5781352           0           0
A57     6088970           0           0
A57      433031           0           0
A57     6089080           0           0
A58     4707857           0           0
A58     6520250           0           0
A58      432308           0           0
A58     6523426           0           0
A59     5778321           0           0
A59     6085478           0           0
A59      433368           0           0
A59     6084297           0           0
A60     4707874           0           0
A60     6522656           0           0
A60      432532           0           0
A60     6522819           0           0
A61     5778778           0           0
A61     6085410           0           0
A61      432778           0           0
A61     6090370           0           0
A62     4707464           0           0
A62     6520618           0           0
A62      432396           0           0
A62     6523770           0           0
A63     5778754           0           0
A63     6087235           0           0
A63      432131           0           0
A63     6078702           0           0
ADDRESS  EXPECTED  ACTUAL  REREAD1  REREAD2  FAILBITS TYPE  P L E I ROW  COL BO
1064f0ac 00000000 000000ff 000000ff 000000ff 000000ff WRITE A 1 0 4 0832 197 3
后面还有一大堆是十六进制的颜色的数值,只对软件了解,硬件不懂,这个怎么下手
发表于 2015-6-9 08:59:16 | 只看该作者 �
没有帮帮我这个小白吗
发表于 2015-6-9 09:23:09 | 只看该作者 �
八颗显存中的第二颗有问题。
