查看: 6477|回复: 4
[转贴]打印机主要集成电路和晶体管
发表于 2008-12-24 21:25:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
序号打印机型号CPU(主CPU)从CPU门阵列电路接口电路字车电机控制与驱动输纸电机控制与驱动打印头控制与驱动
1EPSON LQ-100UPD7810HG  E05A71CASMA7029MC4496×45DC03×6
2EPSON LQ-150KUPD7810HG
3EPSON LQ-510UPD7810HG  E05A0510SLA7020 E05A02LA+晶体管
4EPSON LQ-1070+TMP90C041 E05A86HGE05A50BCAD6712STA475SMA6501
5EPSON LQ-800/1000UPD7810HG  SLA5040STK6982C3293×4C3705×24
6EPSON LQ-1500Z80A8041和8042 8255AC-5STK6982HA13007D1392×24
7EPSON LQ-1600KUPD7810HG E05A10AAM54610PE05A09BAE05A02LA D1978×24
STK6722HD560×4
8EPSON LQ-1600KⅡTMP90C041F  E05A50BCSTK6712PU1501STA475
9EPSON LQ-1800KTMP90C041  E0550BBSTK6022B
10EPSON LQ-1900KTMP90C041F  E05A49BBSLA7024MPU1501UPA1428
11EPSON LQ-2000KD78213GQ E05A21ABE05A24GHE05A02LA+晶体管
 SLA7026MPU4126
12EPSON LQ-2500KUPD7810HG  E05020AASI7300AC3293×4E05A02+晶体管
13EPSON RX-80UPD7810   2SC3293×42SC3293×42SC3293×9
14EPSON MX-808049/80398041/8741 8115晶体三极管4只晶体三极管4只晶体三极管9只
15EPSON FX-80/100/80+/100+7810/78118042 门电路UPA79C+STK6982UPA79C+HA13007UPA79C+D1218×9
16EPSON LX-800UPD7810HG  E5A03EAC4169C4169D1647
17STAR AR-3200TMP90C041  LC92015C-XBL3SLA4030STA4750ATMP4020
18STAR AR-2463UPD7810UPD7810 M54610PPMM8714+D1308×4STA404AUPD65006 STA403×6
19STAR AR-3240TMP90C841 D65006-015UPD65006CW-LCD1725×4STA404ASTA405A×6
20STAR AR-3240+TMP90C041  H24W-1SMA5102SMA6511TMP4303
21STAR AR-4400D70108TMP90-C041 HG62E66R96FSICHSLA7026MSTA404ALC920C0A-FIGA2SLA4060
22STAR CR-3240TMP90C041 D65012CW-ZB2LC92018B-ZB2SLA7026MSTA404AMP4303
23STAR CR-3200TMP90C041 D65006-015MB624134U-XBENC1310STA404AMP4106×6
24STAR CR-3240IITMP90C041  ZBZGA1SLA7026MATA404ASM4032
25STAR AR-2400TMP90C041  LC92015CSTA401ASTA471ASTA471A
26BROTHER M-1724M50734FP  M60005-0220FPTH3L20TH3L20M505-021FP,M5248P×6
27BROTHR M-1324M60043-101EP  M50743FPTH3L20晶体管晶体管
28BROTHER M-2724U3775-A D78213GQD23C8001 ECZ-062D1789TH3L20D2388
29BROTHER M-1924M50734FP M60013-151PFM60013-0147PFSLA7020MENC1330-SPIFMTA001M
30BROTHER M-2024HD6803HD6801 7414 7406等STA434ASTA401AMS4567P×6
发表于 2008-12-24 21:26:22 | 只看该作者 �
31BROTHER AX-1900M50734FP M6005-0217FPM60013-0147PFSLA7020MECN1330-SPIVMTA001M
32NEC P6/P7UPD7810UPD7810 8252SD1308×42SD1308×42SD1164×24
33NEC9400UPD780C-18085 8255×22SD560×42SD560×42SD1164×24
34NEC3300D78213GQ  147156-002SLA4031SLA4031STA403A
35NEC6300D70208GF-8  147-36-002,-P24CG6-03H67015CAC9
36OKI83206051 MSM61059MSM6990HA134122SD1472×4MHM2021×2
37OKI 53206051 MSM61059MSM6990HA134122SD1472×4MHM2021×2
38OKI 5330CM80C154V-1  MSM6990HA13412MS4646APHA13412
39OKI MICR319U79H08  MS6990HA13412HA13412MS4646P×6
40PANASONIC KX-P1211TMP90C854F  PSVIGP2404TMP43034AC21TMP4102
41PANASONIC KX-2828TMP90C854F  PSVIGP2404SLA77024MTMP4012TMP4012
42FUJITSU DPK3600MB606508A HD63009ECPMB670535SLA7024SLA7024FT5764M
43FUJITSU DPK3600EMB90706   SLA7024UDN2916LRSMA4032×6
44FUJITSU DPK8100/8200EMB654510  MB670535SMA4033SMA4033SMA4033×6
45FUJITSU DPK8300/8400EHD63C09EP MB654510MB670535SLA7024SMA4033SMA4033×6
46天津 ZH-1600KTMP90C041  CS70 IF60L6506 L298NM5265PHD60 MTA001×3
47TECOVP 1821D8085A  8155HCD768D768D1022
48PINOVIA 2440L1205637D SCX6212 HKUSCX6212 HKUSTK6712 AMKTH3L10ZMTA011
49SAMSUNG SP-2421KTMP9CP041  STL7062-12V
50TOSHIBA 3070SLT9770   TMP4302TMP4501TMP4301
51AMT 325IZ180 IMI7160-6713 TMP4303TMP4303
52CITIZEN 5240SD70208GF-8  P2503-300SI7300ASTA404AFT5764M
53EP-8508031 8255TP42CSN75436ND1415
54长城 2000GB24SFKH  M54610SLA7020MSTA412AMTA001M
55紫金 30708085P  8155P×22SD633×4TD62064PTD62064P×6
发表于 2008-12-25 13:44:00 | 只看该作者 �
很多都是不太常见的机子
发表于 2009-6-8 00:02:17 | 只看该作者 �
不错啊
但都好久的机子了
发表于 2009-6-11 11:43:22 | 只看该作者 �
这个对专业维修很实用   但是有没有能代换的治疗啊  那样更好了
