查看: 2382|回复: 4
第二个6V盘表面测试
发表于 2008-10-29 14:11:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
SA structure test
Selected family ........................... Vulcan
Model ..................................... Maxtor 6V080E0
Firmware .................................. VA111630
Serial .................................... V20KKP2G
Min. cylinder ............................. 7
Max. cylinder ............................. 34351
Checking UList
Error ..................................... Wrong Module Id "37"
HDD configuration module
Id ........................................ 1F
Read ...................................... Yes
Header .................................... DISK
Checksum .................................. Error
Serial number ............................. V20KKP2G
Max LBA ................................... 160086528
Head number ............................... 2
Head map .................................. 2 3
SA head map ............................... 2 3
     Model1 ............................... Maxtor 6V100E0
     Max LBA .............................. 195813072
     Model2 ............................... Maxtor 6V100E0
     Model3 ............................... Maxtor 6V100E0
     Model4 ............................... Maxtor 6V080E0
     Max LBA .............................. 160086528
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV8
Checking User data adaptives
Header .................................... CR0T`
Checking Zone Table
# : Start Cyl:  End Cyl:  SPT
1 :      932:        0: 7142
2 :        0:        0: 7143
3 :     2282:        8:    0
4 :        0:     1140: 1149
5 :        0:    25775:    0
6 :        0:    25776:    0
7 :        2:        0:    0
8 :     1056:     1699:    5
9 :    44408:        0: 1020
10 :    44409:        0: 50619
11 :        0:        0: 50620
12 :     2514:        1:    0
13 :        0:      900: 2504
14 :        0:     3714:    1
15 :        0:     3715:    1
16 :        5:        0:    0
17 :      780:      837:    4
Checking ROM Copy
Check sum Value ........................... 4766
Checking ATA overlays
Header1 ................................... MO
Header2 ................................... 0000
OverlayId ................................. 0003
ROM CRC ................................... Ok
OverlayId ................................. 0004
OverlayId ................................. 0005
OverlayId ................................. 0006
OverlayId ................................. 0007
Checking Techno mode overlays
Header2 ................................... 00..
OverlayId ................................. 0008
OverlayId ................................. 0009
OverlayId ................................. 000A
OverlayId ................................. 000B
OverlayId ................................. 000C
OverlayId ................................. 000D
OverlayId ................................. 000E
OverlayId ................................. 000F
OverlayId ................................. 0010
OverlayId ................................. 0011
OverlayId ................................. 0012
OverlayId ................................. 0013
OverlayId ................................. 0014
OverlayId ................................. 0015
OverlayId ................................. 0016
OverlayId ................................. 0017
OverlayId ................................. 0018
OverlayId ................................. 0019
OverlayId ................................. 001A
OverlayId ................................. 001B
发表于 2008-10-29 14:12:31 | 只看该作者 �
OverlayId ................................. 001C
OverlayId ................................. 001D
OverlayId ................................. 001E
OverlayId ................................. 001F
OverlayId ................................. 0020
OverlayId ................................. 0021
OverlayId ................................. 0022
Checking RZTbl
Error ..................................... Wrong Module Id "78"
Checking P-List
Error ..................................... Wrong Module Id "18"
Checking G-List
Error ..................................... Wrong Module Id "1B"
Checking RZTbl-PList
Error ..................................... Wrong map
Checking HLists
Error ..................................... UBA 6952 Reading error : Maxtor techno command error. Command : 53. Code : 0072 C/H/S : 39091/1/768
Checking security
Header .................................... SECU
User Password ............................. "********************************"
Master Password ........................... "Maxtor*INIT SECURITY TEST STEP*F"
User password setup ....................... No
Master code ............................... FFFE
Security level ............................ HIGH
Checking S.M.A.R.T.
[SMRT_T] .................................. Ok
[SMRT_A] .................................. Ok
[SMRT_AC] ................................. Ok
[SMART_SUMMAR] ............................ Ok
[SMART_ST] ................................ Ok
[SMART_HOSTV] ............................. Ok
Checking FMTI
Id ........................................ 93
Header .................................... Ok
Checking [DISK/PW]
not found
Checking All
Module 00 ................................. Ok
Module 01 ................................. Ok
Module 03 ................................. Ok
Module 04 ................................. Ok
Module 05 ................................. Ok
Module 08 ................................. Ok
Module 09 ................................. Ok
Module 0A ................................. Ok
Module 0B ................................. Ok
Module 0C ................................. Ok
Module 0D ................................. Ok
Module 0E ................................. Ok
Module 0F ................................. Ok
Module 10 ................................. Ok
Module 11 ................................. Ok
Module 12 ................................. Ok
Module 13 ................................. Ok
Module 14 ................................. Ok
Module 16 ................................. Ok
Module 19 ................................. Ok
Module 1A ................................. Ok
Module 1C ................................. Ok
Module 1D ................................. Ok
Module 1E ................................. Ok
Module 1F ................................. Ok
Module 20 ................................. Ok
Module 21 ................................. Ok
Module 22 ................................. Ok
Module 23 ................................. Ok
Module 24 ................................. Ok
Module 25 ................................. Ok
Module 27 ................................. Ok
Module 28 ................................. Ok
Module 29 ................................. Ok
Module 2A ................................. Ok
Module 2B ................................. Ok
Module 2C ................................. Ok
Module 2D ................................. Ok
Module 2F ................................. Ok
Module 30 ................................. Ok
Module 32 ................................. Ok
Module 33 ................................. UBA 6952 Reading error : Maxtor techno command error. Command : 53. Code : 0072 C/H/S : 39091/1/768
Module 34 ................................. Ok
Module 38 ................................. Ok
Module 39 ................................. Ok
Module 3A ................................. Ok
Module 3B ................................. Ok
Module 3C ................................. Ok
Module 3D ................................. Ok
Module 41 ................................. Ok
Module 42 ................................. Ok
Module 43 ................................. Ok
Module 44 ................................. Ok
Module 45 ................................. Ok
Module 46 ................................. Ok
Module 47 ................................. Ok
Module 48 ................................. Ok
Module 49 ................................. Ok
Module 4A ................................. Ok
Module 4B ................................. Ok
Module 4C ................................. Ok
Module 4D ................................. Ok
Module 4E ................................. Ok
Module 4F ................................. Ok
发表于 2008-10-29 14:13:11 | 只看该作者 �
Module 54 ................................. Ok
Module 56 ................................. Ok
Module 57 ................................. Ok
Module 58 ................................. Ok
Module 59 ................................. Ok
Module 5A ................................. Ok
Module 5B ................................. Ok
Module 5C ................................. Ok
Module 5D ................................. Ok
Module 5E ................................. Ok
Module 5F ................................. Ok
Module 60 ................................. Ok
Module 61 ................................. Ok
Module 62 ................................. Ok
Module 63 ................................. Ok
Module 64 ................................. Ok
Module 65 ................................. Ok
Module 66 ................................. Ok
Module 67 ................................. Ok
Module 68 ................................. Ok
Module 69 ................................. Ok
Module 6A ................................. Ok
Module 6B ................................. Ok
Module 6E ................................. Ok
Module 70 ................................. Ok
Module 71 ................................. Ok
Module 72 ................................. Ok
Module 73 ................................. Ok
Module 74 ................................. Ok
Module 75 ................................. Ok
Module 76 ................................. Ok
Module 77 ................................. Ok
Module 79 ................................. Ok
Module 7B ................................. Ok
Module 81 ................................. Ok
Module 82 ................................. Ok
Module 83 ................................. Ok
Module 84 ................................. Ok
Module 85 ................................. Ok
Module 86 ................................. Ok
Module 87 ................................. Ok
Module 88 ................................. Ok
Module 89 ................................. Ok
Module 8A ................................. Ok
Module 8B ................................. Ok
Module 8C ................................. Ok
Module 8D ................................. Ok
Module 8E ................................. Ok
Module 8F ................................. Ok
Module 90 ................................. Ok
Module 92 ................................. Ok
Module 93 ................................. Ok
Module 94 ................................. Ok
Module 96 ................................. Ok
Module 97 ................................. Ok
Module 98 ................................. Ok
Module 99 ................................. Ok
Module 9A ................................. Ok
Module 9B ................................. Ok
Module 9C ................................. Ok
Module 9D ................................. Ok
Module 9E ................................. Ok
Module 9F ................................. Ok
Module A0 ................................. Ok
Module A1 ................................. Ok
Module A2 ................................. Ok
Module A5 ................................. Ok
Module A6 ................................. Ok
Module A9 ................................. Ok
Module AA ................................. Ok
Module AB ................................. Ok
Module AC ................................. Ok
Module AD ................................. Ok
Module AE ................................. Ok
Module AF ................................. Ok
Module B0 ................................. Ok
Module B1 ................................. Ok
Module B2 ................................. Ok
Module B3 ................................. Ok
Module B4 ................................. Ok
Module B6 ................................. Ok
Module B7 ................................. Ok
Module B8 ................................. Ok
Module B9 ................................. Ok
Module BA ................................. Ok
Module BB ................................. Ok
Module BC ................................. Ok
Module BD ................................. Ok
Module BE ................................. Ok
Module BF ................................. Ok
Module C0 ................................. Ok
Module C1 ................................. Ok
Module C2 ................................. Ok
Module C3 ................................. Ok
Module C4 ................................. Ok
Module CB ................................. Ok
Module CD ................................. Ok
Module D0 ................................. Ok
发表于 2008-11-21 01:08:03 | 只看该作者 �
写测试如果通过!可以找SN 型号  校验码一样的盘来写模块!(SN的前三位一样就可以相同更多的会更好,利用提高写模块的成功率)
发表于 2008-12-20 13:47:20 | 只看该作者 �
后来老大说PC3000不支持这个型号的盘,所以出现这样的情况.
