查看: 2983|回复: 4
[显卡维修]
求大神帮忙屏蔽个通道
发表于 2014-3-1 23:32:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
MATS version 4.100.3.  Testing G92 with 768 MB of memory.
Errors found.  Use .Status() or .PrintErrors() for more info.
This message will only appear once.
   LANE    EB0 READ ERR EB0 WRT ERR  EB1 READ ERR EB1 WRT ERR  UNKNOWN ERR
FBB[31: 0]           0            0            0            0            0
FBB[63:32]           0            0            0            0            0
FBC[31: 0]           0            0            0            0            0
FBC[63:32]     2361636     17496194      2358086     34387606            0
FBD[31: 0]           0            0            0            0            0
FBD[63:32]           0            0            0            0            0
External Bank 0 Failing bits:
   C32 C33 C34 C35 C36 C37 C38 C39 C40 C41 C42 C43 C44 C45 C46 C47
   C48 C49 C50 C51 C52 C53 C54 C55 C56 C57 C58 C59 C60 C61 C62 C63
External Bank 1 Failing bits:
Read    Error Count: 4719722
Write   Error Count: 51883800
Unknown Error Count: 0
BIT  FRONT WRITE  FRONT READ  BACK WRITE  BACK READ    UNKNOWN
C32     3793793       53431     5121812      153245           0
C32     3799595       52439     5159591      821788           0
C32     1203531       22209     5451415      134161           0
C32     1188604     1354962     6631130      155562           0
C33     5058535      776500     8200970      598163           0
C33     5072563      106302     8236502      938090           0
C33     3703655       73787     8379990      540096           0
C33     3651731     1403850     9555526      280671           0
C34     3794123       53443     5122473      153258           0
C34     3799925       52480     5160251      822056           0
C34     1203603       22203     5452728      134123           0
C34     1188677     1355488     6632990      155624           0
C35     5058431      776546     8200797      598188           0
C35     5072463      106289     8236340      938046           0
C35     3703727       73785     8379969      540088           0
C35     3651804     1403792     9555526      280691           0
C36     3794423       53518     5122666      153292           0
C36     3800209       52470     5160507      822004           0
C36     1203510       22209     5452632      134205           0
C36     1188583     1355378     6632918      155558           0
C37     5059165      776481     8201880      598182           0
C37     5073177      106333     8237406      938302           0
C37     3703634       73785     8381139      540098           0
C37     3651710     1404364     9557234      280671           0
C38     3794179       53496     5122547      153261           0
C38     3799971       52489     5160367      822048           0
C38     1203582       22203     5452761      134153           0
C38     1188656     1355424     6633020      155592           0
C39     5058487      776493     8200927      598163           0
C39     5072509      106298     8236444      938034           0
C39     3703706       73783     8379934      540076           0
C39     3651783     1403826     9555476      280663           0
C40     3793718       53377     5121867      153245           0
C40     3799531       52442     5159601      821778           0
C40     1203569       22204     5451417      134148           0
C40     1188646     1354980     6631057      155579           0
C41     5058460      776536     8200933      598167           0
C41     5072499      106307     8236478      938084           0
C41     3703693       73786     8380020      540101           0
C41     3651773     1403796     9555527      280680           0
C42     3794048       53389     5122528      153258           0
C42     3799861       52483     5160261      822046           0
C42     1203641       22198     5452730      134110           0
C42     1188719     1355506     6632917      155641           0
C43     5058356      776582     8200760      598192           0
C43     5072399      106294     8236316      938040           0
C43     3703765       73784     8379999      540093           0
C43     3651846     1403738     9555527      280700           0
C44     3793708       53434     5121713      153266           0
C44     3799507       52437     5159493      821772           0
C44     1203548       22204     5451492      134176           0
C44     1188625     1354938     6631165      155551           0
C45     5058450      776487     8200835      598160           0
C45     5072475      106302     8236358      938074           0
C45     3703672       73784     8380027      540087           0
C45     3651752     1403852     9555555      280656           0
C46     3793464       53412     5121594      153235           0
C46     3799269       52456     5159353      821816           0
C46     1203620       22198     5451621      134124           0
C46     1188698     1354984     6631267      155585           0
C47     5057772      776499     8199882      598141           0
C47     5071807      106267     8235396      937806           0
C47     3703744       73782     8378822      540065           0
C47     3651825     1403314     9553797      280648           0
C48     3793436       53349     5121398      153242           0
C48     3799253       52419     5159140      821668           0
C48     1203559       22212     5450877      134127           0
C48     1188636     1354756     6630240      155574           0
C49     5058178      776528     8200444      598156           0
C49     5072221      106278     8235983      937970           0
C49     3703685       73784     8379426      540094           0
C49     3651763     1403568     9554668      280667           0
C50     3793766       53361     5122059      153255           0
C50     3799583       52460     5159800      821936           0
C50     1203631       22206     5452190      134089           0
C50     1188709     1355282     6632100      155636           0
C51     5058074      776574     8200271      598181           0
C51     5072121      106265     8235821      937926           0
C51     3703757       73782     8379405      540086           0
C51     3651836     1403510     9554668      280687           0
C52     3794066       53436     5122252      153289           0
C52     3799867       52450     5160056      821884           0
C52     1203538       22212     5452094      134171           0
C52     1188615     1355172     6632028      155570           0
C53     5058808      776509     8201354      598175           0
C53     5072835      106309     8236887      938182           0
C53     3703664       73782     8380575      540096           0
C53     3651742     1404082     9556376      280667           0
C54     3793822       53414     5122133      153258           0
C54     3799629       52469     5159916      821928           0
C54     1203610       22206     5452223      134119           0
C54     1188688     1355218     6632130      155604           0
C55     5058130      776521     8200401      598156           0
C55     5072167      106274     8235925      937914           0
C55     3703736       73780     8379370      540074           0
C55     3651815     1403544     9554618      280659           0
C56     3793933       53329     5122319      153252           0
C56     3799767       52456     5160036      821906           0
C56     1203597       22207     5452035      134126           0
C56     1188678     1355260     6631951      155615           0
C57     5058675      776598     8201273      598170           0
C57     5072735      106317     8236845      938212           0
C57     3703723       73783     8380612      540111           0
C57     3651805     1404000     9556453      280700           0
C58     3794263       53341     5122980      153265           0
C58     3800097       52497     5160696      822174           0
C58     1203669       22201     5453348      134088           0
C58     1188751     1355786     6633811      155677           0
C59     5058571      776644     8201100      598195           0
C59     5072635      106304     8236683      938168           0
C59     3703795       73781     8380591      540103           0
C59     3651878     1403942     9556453      280720           0
C60     3793923       53386     5122165      153273           0
C60     3799743       52451     5159928      821900           0
C60     1203576       22207     5452110      134154           0
C60     1188657     1355218     6632059      155587           0
C61     5058665      776549     8201175      598163           0
C61     5072711      106312     8236725      938202           0
C61     3703702       73781     8380619      540097           0
C61     3651784     1404056     9556481      280676           0
C62     3793679       53364     5122046      153242           0
C62     3799505       52470     5159788      821944           0
C62     1203648       22201     5452239      134102           0
C62     1188730     1355264     6632161      155621           0
C63     5057987      776561     8200222      598144           0
C63     5072043      106277     8235763      937934           0
C63     3703774       73779     8379414      540075           0
C63     3651857     1403518     9554723      280668           0
这是mats测试结果~~应该是有一个闪存坏了~~现在花屏想屏蔽一个通道试下还花不~~求大神帮忙屏蔽一下~~谢谢
G92.zip (39.39 KB, 下载次数: 4)
发表于 2014-3-1 23:42:24 | 只看该作者 �
bios我是用GPU Z保存下来得
发表于 2014-3-1 23:32:49 | 只看该作者 �
bios我是用GPU Z保存下来得
发表于 2014-3-3 10:51:04 | 只看该作者 �
这貌似难道很高,要改bios
发表于 2014-6-18 09:16:39 | 只看该作者 �
你看下这个贴吧。。。 http://www.chinafix.com/thread-472941-1-2.html  这是屏蔽C通道的
