查看: 6234|回复: 0
发个WD TREX使用说明
发表于 2013-11-15 14:13:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
无修改,全英文,找有道翻译竟然需要26W,只好自己研究了.
TREX
User Guide
For Version 1.182.505
December 20th, 2006
Table of Contents
1. Introduction 7
1.1. Purpose 7
1.2. System Requirements 7
2. General Notes 8
2.1. Bug reporting 8
2.2. Definitions and Abbreviations 8
2.3. DOS Command Line Options 9
2.4. Startup Resource Allocation 11
2.5. Required files to run TREX 11
2.6. Running under Windows 95 / 98 / ME 11
2.7. Optional TREX.INI file 13
2.8. Memory Considerations 13
2.9. Linear vs Physical Memory 13
2.10. Large Drive Support (> 32GB) 14
2.11. Very Large Drive Support (> 128GB) 14
2.12. Native Mode Support 14
2.13. Vendor Specific Commands (VSC) Support 14
2.14. Scan for Drives 14
2.15. Issuing Commands 15
2.16. Using TREX 15
2.17. TREX Screens 15
2.18. TREX Examples 19
2.18.1. Using TREX’s High Level Drive Commands 19
2.18.2. General Buffer Manipulations 19
3. Drive Commands 20
3.1. ATA/ATAPI High-Level commands 30
3.2. High level Native Mode and Vendor Specific Commands (VSC) 79
3.3. Automated Queued DMA commands 93
3.4. Low level protocol commands 95
3.4.1. Low level Examples 95
3.5. Task File Registers 98
3.5.1. Task File Examples 98
3.6. SATA Power Management 105
3.7. AV/C Commands 105
4. Variables 110
5. Misc Commands 150
6. Introduction to Kernel Commands 166
7. Arithmetic Operations 166
7.1. Unary 166
7.2. Binary 166
7.3. C-style Arithmetic Operators 166
7.4. Set Equal 167
7.5. Parenthetic Expressions 167
8. Bit-wise Operations 167
8.1. Unary 167
8.2. Binary 167
8.3. C-style Arithmetic Operators 167
8.4. Shift Operations 167
9. Boolean Operations 168
9.1. Unary 168
9.2. Binary 168
9.3. Comparison 168
9.4. Bit-wise 168
9.5. From Assembly Language 169
10. Buffer Management 169
10.1. Buffer Allocation/Deallocation 169
10.2. Buffer Variables 173
10.3. Buffer Compare 173
10.4. Buffer/User String Copy 176
10.5. Buffer Dump 177
10.6. Buffer Edit 177
10.7. Buffer Load & Save 178
10.8. Buffer Patterns 179
10.9. Where When What Pattern Details 181
10.10. Raw Memory 186
10.11. ATA 16-bit CRC calculation 189
10.12. CRC32 calculation 189
10.13. Miscellaneous CRC Commands 190
11. Comma Separated Value File Support 191
11.1. Input File Support 191
11.1.1. Management 191
11.1.2.Supported Field types 191
11.2.Output File Support 192
11.2.1. Management 192
11.2.2. Printing 193
12. Debug Commands 193
12.1. Run Time checks 193
12.2. Debug Flag support 194
12.3. Expression Watch Support 194
12.3.1. Expression Watch Example 195
12.4. Event Handler Debug 196
13. Delays 196
13.1. High Resolution, Short Duration 196
13.2. Low Resolution, Long Duration 197
14. Elapsed Time 197
15. Event Handlers 198
15.1. Basic syntax 198
15.2. Specific events supported 199
16. Floating Point Support 207
16.1. Arithmetic Operations 207
16.2. Comparison 209
16.3. Utility Functions 210
16.4. Register Storage 211
16.5. Arbitrary Memory Location Storage 212
16.6. Floating point Output 212
17. Line Repeat 214
18. Literal Values 214
18.1. Keyboard scan code (returned via Kbrd) 214
18.2. Screen Attributes 215
18.3. Literal 1 <On> 215
18.4. Literal 0 <Off> 216
19. Log File Support 216
19.1. Management 216
19.2. Print Flags 216
19.3. Printing 217
19.4. Viewing 218
20. Low-Level File Support 218
20.1. File Utilities 218
20.2. Accessing Arbitrary Files via Handles 220
20.3. General purpose File Find 225
21. Message Window & Screen Output 227
21.1. Message Window Output 227
21.2. Arbitrary Screen Location Output 230
21.3. Arbitrary Screen View 231
22. Miscellaneous Commands / Symbols 232
23. Network File Support 252
23.1. Management 252
23.2. Printing 252
24. Pointers 252
25. Port I/O 253
25.1. Base Port Relative 253
25.2. PCI Port Relative 254
25.3. PCI Register Access 256
25.4. Fixed Port Addresses 258
26. Procedures & Script File Management 259
26.1. Comments 259
26.2. Launching Scripts 259
26.3. Ultra Large Script files 260
26.4. Bit Maps 260
26.5. Byte Maps (A variant of c-style structures) 261
26.6. Macros 263
26.7. Procedure Block Terminators 263
26.8. Macro Tables 263
26.9. Random Macro Lists 264
26.10. Function Key Macros 266
26.11. Subroutines 266
26.12. User Defined Commands 266
26.13. Inline code 267
26.14. Source File Location pseudo macros 267
26.15. Process Control 268
26.16. Miscellaneous Procedure Commands 268
27. Pre-Processor Statements 269
28. Program Flow Control 270
28.1. Conditional Branching 270
28.2. Unconditional Branching 272
28.3. Conditional Looping 273
29. Process Control 273
30. Random Numbers 273
30.1. List-Based 273
30.2. Named Random Fields 275
30.3. Timer Based 275
30.4. Next Seed 276
31. PC-H/W Based Serial Communication Channel 276
31.1. Channel Setup 276
31.2. Channel Tests 278
31.3. Channel Low Level I/O 281
31.4. Channel High Level I/O 282
32. PCI-Card Based Serial Communication Channel 283
32.1. Channel Setup 283
32.2. Channel Access 284
32.3. Channel Low Level I/O 284
Trex原版说明书.rar
1.37 MB, 下载次数: 224, 下载积分: 下载分 -2 分, 下载 1 次
