- 积分
- 96
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2012-12-17
- 精华
昨天又出现了,详细提示如下:
A Problem has been detected and windows hasn been shut down to prevent damage to your computer
IRQL_NOT_LESS_OR_EQUAL
if this is the first time you've seen this stop error screen,restart your computer .if this screen appears again,fpllow
these steps:
check omake sure anynew hardware or software is properly installed.
ifthis is a new installation,ask your hardware or software manufacturer
for any windows updates you might need
if problems continue ,disable or remove any newly installed hardware or software.Disable BIOS memory options such as caching or shadowing.
if you need to use safe mode to remove ordisable componens,restart your computer,press F8 to select Advanced Startup Options,and then select safe mode.
STOP:0X000000A(0X98FFFFF4,0X00000002,0X00000000, 0X804E75F6)
补充说明:前段时间也出现过一次.是开机以后正常工作过程中出现,并不是开机启动的时候出现,出现的频率不高,偶尔出现
机器使用两根内存条,一根256MB,另一根512MB
