查看: 2306|回复: 1
Acer Travelmate XXXX Dead After Bios Flash
发表于 2013-3-16 23:20:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Here's the solution. I copied the answer because my english is bad, but I want to help other people with my same problem... and IT WORKS!!!!! I also screwed up with the 1.12 Bios version for the Acer Travelmate 2200. But, fortunately everything works again. With a lot of googling and going to this site, i finally got the solution. What you've got to do: 1) Get a USB floppy drive. (you get them for little money on second hand auction shops and a clean floppy.) On another pc:
2) Download the vX.XX version from the Acer ftp site.
Code:
3) Download CRISISDISK AND PEN   CrisDisk and Pen Drive Recovery1.part1.rar (1.91 MB, 下载次数: 2)
发表于 2013-3-16 23:29:21 | 只看该作者 �
哥,你译好后再发出来行不?搞得人很迷糊!
把它粘贴到“有道词典”里简单翻译下或许可以看出点眉目  发表于 2013-3-18 15:33
