查看: 5448|回复: 7
[维修资料]
希捷ST3500320AS解密--指令全程
发表于 2012-10-19 15:33:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
F3 2>s21FED,00,22
F3 2>r,10d,1
F3 2>B1708,1708
Buffer Block 1708 compared to Buffer Block 1708 (200 Bytes/Block)
  Addr    0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F
002E1000  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1010  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1020  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1030  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1040  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1050  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1060  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1070  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1080  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1090  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1100  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1110  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1120  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1130  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1140  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1150  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1160  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1170  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1180  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1190  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F3 2>C1708,1708,1
F3 2>s21FED,00,22
F3 2>w,10d,1
F3 2>
补充内容 (2012-10-28 21:40):
这个是用超级终端输入的指令全过程。先/2回车进入二级F3 2>,再依次输入指令s21FED,00,22     r,10d,1    B1708,1708,其中FF FF...是自动显示的缓冲区数据,是全部FF的就表示密码被清除。再指令保存C1708,1708,1...
发表于 2012-10-19 15:38:40 | 只看该作者 �
发表于 2012-10-19 15:47:32 | 只看该作者 �
什么意思啊
发表于 2012-10-19 16:39:01 | 只看该作者 �
实在是高,不懂啊
发表于 2012-10-22 13:23:16 | 只看该作者 �
看不懂什么意思。。楼主解释下,
发表于 2012-11-1 13:05:38 | 只看该作者 �
这个还还真就没试过,保存下来试试看可以搞定不  先谢谢楼主这么高尚的风格
发表于 2012-11-1 21:41:39 | 只看该作者 �
不是所有都一样的
发表于 2017-7-18 17:21:20 | 只看该作者 �
指令解密
