查看: 2238|回复: 0
[显卡维修]
X1950XTX R5检测出错情高手看看,谢谢!
发表于 2012-10-19 09:44:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 贵州贵阳 来自 贵州贵阳
显卡出错是逆时针第2颗吧?故障严重吗?
R5MEMID version 1.03, (c) Copyright ATI Technologies Inc, 2006
Log file generation enabled to .\R5MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
  [1] Mem production test FB001
    Failing Bits
      rk0 chB: 0
  [2] Mem production test FB063
    Failing Bits
      rk0 chB: 0
  [3] Mem production test FB064
    Failing Bits
      rk0 chB: 0
  [4] Mem production test FB065
    Failing Bits
      rk0 chB: 16
  [5] Mem production test FB066
    Failing Bits
      rk0 chB: 0
  [6] Modified FB088
    Failing Bits
      rk0 chB: 0
  [7] Modified FB091
    Failing Bits
      rk0 chB: 0
[1  ] Mem production test FB001                           : FAIL
    Error ID G0FB096
  1024 x  768 - argb8888 (60 Hz): TEST FAILURE
    Error count: total[16744448] chB[16744448]
[2  ] Mem production test FB063                           : FAIL
    Error ID G0FB096
    Error count: total[141824] chB[141824]
[3  ] Mem production test FB064                           : FAIL
    Error ID G0FB096
[4  ] Mem production test FB065                           : FAIL
    Error ID G0FB096
    Error count: total[523264] chB[523264]
[5  ] Mem production test FB066                           : FAIL
    Error ID G0FB096
    Error count: total[539392] chB[539392]
[6  ] Modified FB088                                      : FAIL
    Error ID G0FB088
    Error count: total[3072] chB[3072]
[7  ] Modified FB091                                      : FAIL
    Error ID G0FB091
TEST RESULT SUMMARY:
R580/M59 (0x7240) detected.
512M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
    Error ID G0FB096
    Error ID G0FB096
    Error ID G0FB096
    Error ID G0FB096
    Error ID G0FB096
    Error ID G0FB088
    Error ID G0FB091
Failure detected.
