查看: 2709|回复: 6
[显卡维修]
看不懂了,X550花屏测试结果,高手帮帮忙啊 16-63全部错误
发表于 2012-5-26 15:21:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 河南洛阳 来自 河南洛阳
运行参数是 metest -nocfg -bit -logext *,高手帮我分析下啊,双128,正面四个,背面四个
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
  [1] Fill
Failing bits in test [1] Fill
  errcount: 2
  MDA0: 16 17 18 21 22 23 32 33 41 43 44 46 49 50 52 53 54 55 57 59 60 61 62 63
Failing bits in test [2] Data line toggle (GUI)
  errcount: 9821058
  MDA0: 16 17 18 19 20 21 22 23 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Failing bits in test [3] RW column (GUI)
  errcount: 9464820
Failing bits in test [4] RW page (GUI)
  errcount: 9526114
Failing bits in test [5] RW channel (GUI)
  errcount: 10992421
Failing bits in test [6] Data mask
  errcount: 18656337
Failing bits in test [7] Macro + Micro8x2 tiling read
  errcount: 4639432
Failing bits in test [8] Macro + Micro4x4 tiling write
  errcount: 4276999
Failing bits in test [9] Byte swap macro+micro8x2 read
  errcount: 32377122
Failing bits in test [10] Byte swap macro+micro4x4 write
  errcount: 32380758
Failing bits in test [11] Marco+Micro8x2 alignment write
  errcount: 37378
  MDA0: 16 17 20 22 23 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 49 50 52 53 54 55 56 57 58 59 60 61 62 63
Failing bits in test [12] Macro+Micro4x4 alignment read
  errcount: 37379
  MDA0: 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 52 53 54 55 56 57 58 59 60 61 62 63
TEST RESULT SUMMARY:
RV370/M22 A12b (0x5b60) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 16 17 18 21 22 23 32 33 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDA0 16 17 18 19 20 21 22 23 ...
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
    failing bit : MDA0 16 17 20 22 23 32 33 34 ...
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
    failing bit : MDA0 32 33 34 35 36 37 38 39 ...
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
Failure detected.
补充内容 (2012-5-28 08:58):
它的排列顺序应该是这样的  A通道对应的是29 30 33 34 B通道对应的是 31 32 35 36这样交叉排列的。显示时屏上正好符合这样的规则 。把屏按竖线平均隔成4份1|2|3|4。故障正好是1.3花屏。不知道说的对不对。有望高手解
同意楼主: 0.0
同意楼主: 0
  发表于 2012-5-26 18:12
发表于 2012-5-26 15:41:50 | 只看该作者 来自: 湖北武汉 来自 湖北武汉
写那么多看不明白的东东干嘛!直奔主题嘛!
同意楼主: 2.5
同意楼主: 0
  发表于 2012-5-27 14:45
同意楼主: 5
  发表于 2012-5-26 18:00
发表于 2012-5-27 10:25:33 | 只看该作者 来自: 河南洛阳 来自 河南洛阳
发表于 2012-5-27 12:24:19 | 只看该作者 来自: 河南洛阳 来自 河南洛阳
显卡修好了,经过不停断开排阻,确定故障点在 34上面,对应的16 17 18 19 20 21 22 23.不知道对不对。反正就是加焊这里的排阻就好了
对于这类显卡,我就是测量一下各路供电,然后加焊,不行就扔在一边。  发表于 2012-5-27 12:54
发表于 2012-5-27 15:27:25 | 只看该作者 来自: 河南洛阳 来自 河南洛阳
qw7436867 发表于 2012-5-27 12:24
显卡修好了,经过不停断开排阻,确定故障点在 34上面,对应的16 17 18 19 20 21 22 23.不知道对不 ...
发错啦,故障在33上面。ATI先我加焊就没加好过啊。都是显存了
发表于 2012-5-27 18:48:37 | 只看该作者 来自: 山东青岛 来自 山东青岛
ati的卡确实不太好加焊
发表于 2012-5-27 23:07:01 | 只看该作者 来自: 浙江宁波 来自 浙江宁波
我也是看的头晕了,幸好楼主修好了
