查看: 2321|回复: 4
[显卡维修]
MATS 结果高手马上给我看下
发表于 2012-4-17 13:24:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
MATS version 4.100.3.  Testing G73 with 128 MB of memory.
Errors found.  Use .Status() or .PrintErrors() for more info.
This message will only appear once.
   LANE    EB0 READ ERR EB0 WRT ERR  UNKNOWN ERR
FBA[31: 0]           0         3946            0
FBA[63:32]           0         1462            0
FBC[31: 0]           0         2203            0
FBC[63:32]           0        22519            0
External Bank 0 Failing bits:
   A00 A01 A02 A03 A04 A05 A06 A07 A08 A09 A10 A11 A12 A13 A14 A15
   A16 A17 A18 A19 A20 A21 A22 A23 A24 A25 A26 A27 A28 A29 A30 A31
   A32 A33 A34 A35 A36 A37 A38 A39 A40 A41 A42 A43 A44 A45 A46 A48
   A49 A50 A51 A52 A55 A56 A57 A58 A59 A60 A61 A62 A63 C00 C01 C02
   C03 C04 C05 C06 C07 C08 C09 C10 C11 C12 C13 C14 C15 C16 C17 C18
   C19 C20 C21 C22 C23 C24 C25 C26 C27 C28 C29 C30 C31 C32 C33 C34
   C35 C36 C37 C38 C39 C40 C41 C42 C43 C44 C45 C46 C47 C48 C49 C50
   C51 C52 C53 C54 C55 C56 C57 C58 C59 C60 C61 C62 C63
Read    Error Count: 0
Write   Error Count: 30130
Unknown Error Count: 0
BIT  FRONT WRITE  FRONT READ  UNKNOWN
A00          19           0           0
A00         223           0           0
A00         220           0           0
A00         251           0           0
A01           5           0           0
A01          85           0           0
A01         169           0           0
A01         349           0           0
A02          29           0           0
A02         161           0           0
A02          87           0           0
A02         162           0           0
A03          34           0           0
A03         155           0           0
A03          29           0           0
A03          60           0           0
A04          80           0           0
A04          17           0           0
A04           7           0           0
A04          18           0           0
A05           4           0           0
A05          15           0           0
A05          98           0           0
A05           2           0           0
A06          15           0           0
A06          11           0           0
A06          42           0           0
A06          10           0           0
A07          44           0           0
A07           2           0           0
A07           9           0           0
A07          24           0           0
A08           5           0           0
A08           1           0           0
A09           2           0           0
A09           1           0           0
A09           1           0           0
A10           4           0           0
A10           2           0           0
A10           1           0           0
A11           1           0           0
A11           1           0           0
A12           6           0           0
A12           1           0           0
A12           7           0           0
A12          32           0           0
A13           9           0           0
A13          17           0           0
A13          48           0           0
A13          38           0           0
A14           1           0           0
A14          45           0           0
A14           5           0           0
A15           2           0           0
A15           7           0           0
A16           4           0           0
A16           2           0           0
A16           4           0           0
A16           2           0           0
A17           7           0           0
A17           1           0           0
A17           1           0           0
A17           1           0           0
A18          17           0           0
A18           2           0           0
A18           3           0           0
A19           5           0           0
A19           1           0           0
A19           5           0           0
A20           5           0           0
A20           5           0           0
A20          10           0           0
A20          18           0           0
A21           1           0           0
A22           2           0           0
A23           7           0           0
A23          12           0           0
A24           3           0           0
A24           1           0           0
A24           2           0           0
A24           2           0           0
A25          15           0           0
A25           6           0           0
A25          10           0           0
A25           8           0           0
A26           3           0           0
A26          15           0           0
A26         172           0           0
A27           6           0           0
A27           6           0           0
A27           4           0           0
A28          59           0           0
A28         187           0           0
A28          23           0           0
A28           1           0           0
A29           6           0           0
A29           6           0           0
A29          60           0           0
A29          16           0           0
A30          20           0           0
A30          32           0           0
A30          27           0           0
A30          12           0           0
A31         349           0           0
A31          43           0           0
A31          54           0           0
A31          28           0           0
A32          11           0           0
A32           2           0           0
A32           3           0           0
A32           1           0           0
A33           3           0           0
A33          36           0           0
A33           7           0           0
A33          25           0           0
A34          39           0           0
A34          14           0           0
A34           9           0           0
A34          16           0           0
A35          18           0           0
A35          13           0           0
A35           1           0           0
A36          30           0           0
A36          35           0           0
A36          34           0           0
A36           4           0           0
A37          46           0           0
A37         177           0           0
A37          10           0           0
发表于 2012-4-17 22:26:47 | 只看该作者 �
全部报错,BIOS刷错了,或者显存全坏了,第三种情况极少见,GPU空焊(这种情况一般不会全部出错的)
发表于 2012-4-19 10:54:28 | 只看该作者 �
太明显的满天星,测试出来都这样。
发表于 2012-4-19 21:49:31 | 只看该作者 �
更换使用MATS8程序再付上来。
发表于 2012-4-19 22:55:59 | 只看该作者 �
看看显存是不是三星的,如果是显存可能全坏了。
