查看: 2301|回复: 5
[显卡维修]
9550用R3MEMID测试,结果看不明白,求救!
发表于 2012-3-17 03:52:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广西南宁 来自 广西南宁
代码如下:
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
Failing bits in test [1] Fill
  errcount: 49123
  MDA0: 0 1 2 3 20 21 22 23 56 57 58 59 60 61 62 63
  MDB0: 48 49 50 51 52 53 54 55
Failing bits in test [2] Data line toggle (GUI)
  errcount: 16594
  MDA0: 56 57 58 59 60 61 62 63
Failing bits in test [3] RW page (GUI)
  errcount: 24578
Failing bits in test [4] RW channel (GUI)
  errcount: 24585
  MDA0: 0 1 2 3 20 21 22 23 61 62 63
Failing bits in test [5] Data mask
  errcount: 40964
  MDA0: 0 1 2 3 20 21 22 23 56 59 60 61 62 63
  MDB0: 48 49 50 51 53 55
Failing bits in test [6] Macro + Micro8x2 tiling read
  errcount: 6148
  MDA0: 20 21 56 57 60 61 62 63
Failing bits in test [7] Byte swap macro+micro8x2 read
  errcount: 33570530
  MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
TEST RESULT SUMMARY:
Rv350 (0x4154) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 20 21 22 23 ... MDB0 48 49 50 51 52 53 54 55
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
    failing bit : MDA0 56 57 58 59 60 61 62 63 MDB0 48 49 50 51 52 53 54 55
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
    failing bit : MDA0 0 1 2 3 20 21 22 23 ... MDB0 48 49 50 51 53 55
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
    failing bit : MDA0 20 21 56 57 60 61 62 63 MDB0 48 49 50 51 52 53 54 55
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.8 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.8 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.8 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.8 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.8 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.8 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.8 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.8 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.8 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.8 not found
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.8 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.8 not found
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
     error : R051A.9 not found
     error : R052A.9 not found
     error : R053A.9 not found
     error : R055A.9 not found
     error : R061A.9 not found
     error : R062A.9 not found
     error : R063A.9 not found
     error : R065A.9 not found
     error : R071A.9 not found
     error : R072A.9 not found
     error : R073A.9 not found
     error : R075A.9 not found
Failure detected.
补充内容 (2012-3-17 17:38):
显卡只是小花,不管是在DOS还是WINDOWS,不死机,怎么A通道这么多坏的,是核心虚焊吗
处理好test1的错误就可以了  发表于 2012-4-3 14:55
发表于 2012-3-17 09:42:25 | 只看该作者 来自: 陕西西安 来自 陕西西安
两个通道都有报错....
发表于 2012-3-17 17:45:37 | 只看该作者 来自: 广东湛江 来自 广东湛江
两个通道都有报错
应该是核心问题,加焊
发表于 2012-3-27 05:19:28 | 只看该作者 来自: 广西南宁 来自 广西南宁
加焊无果,比原来还差些
发表于 2012-3-27 17:46:02 | 只看该作者 来自: 云南昆明 来自 云南昆明
看第一组报错就可以了,没有那么麻烦
发表于 2012-4-2 20:09:32 | 只看该作者 来自: 四川成都 来自 四川成都
谢谢了 还没修过显卡 正好看看可以练练手
