查看: 1564|回复: 0
Kaspersky TDSSKiller 2.7.5.0
发表于 2012-1-19 14:06:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
A rootkit is a program or a program kit that hides the presence of malware in the system.
A rootkit for Windows systems is a program that penetrates into the system and intercepts the system functions (Windows API). It can effectively hide its presence by intercepting and modifying low-level API functions. Moreover it can hide the presence of particular processes, folders, files and registry keys. Some rootkits install its own drivers and services in the system (they also remain “invisible”).
Kaspersky Lab has developed the TDSSKiller utility that allows removing rootkits.
The utility supports 32-bit and 64-bit operation systems.
The utility can be run in Normal Mode and Safe Mode.
It detects and removes the following malware:
malware family Rootkit.Win32.TDSS;
bootkits;
rootkits.
卡巴斯基出品的反病毒和rootkits扫描工具.免费使用.
