查看: 3814|回复: 3
[内存维修]
求DDR3 1333 2G双面的SPD
发表于 2011-12-4 12:09:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
麻烦谁手里用的2G DDR3 1333双面的内存 备份出来个SPD呗 谢谢
同意楼主: 1.0
同意楼主: 1
y  发表于 2012-1-12 12:43
发表于 2011-12-5 10:12:48 | 只看该作者 �
Organization :256M*64 DDRⅢ1333 240pin
Composition :128M*8-16EA Hynix
Programmable CAS Latency DRⅢ1333(9 clock)
16进位显示
(000~015) 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 3C 00
(016~031) 69 78 69 30 69 11 20 89 70 03 3C 3C 00 F0 83 05
(032~047) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(048~063) 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01
(064~079) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(080~095) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(096~111) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(112~127) 00 00 00 00 00 80 AD 01 0B 11 00 00 00 00 B5 26
(128~143) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(144~159) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(160~175) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(176~191) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(192~207) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(208~223) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(224~239) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(240~255) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
同意楼主: 5.0
H55
同意楼主: 5
对  发表于 2011-12-5 18:33
发表于 2011-12-5 23:40:06 | 只看该作者 �
谢谢 我自己整理一下
头像被屏蔽
4#
发表于 2011-12-29 15:42:34 | 只看该作者 �
发给你,你改成双面就可以。
EK_DDR3_1G_1600M_8PCS_CS.zip
281 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR3_1G_1333M_8PCS_OCZ.zip
288 Bytes, 下载次数: 1, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR3_1G_1333M_8PCS_NA.zip
273 Bytes, 下载次数: 2, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR3_1G_1333M_8PCS_CM.zip
317 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR3_1G_1333M_8PCS_CL.zip
306 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR3_1G_1066M_8PCS_CS.zip
284 Bytes, 下载次数: 3, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR2_1G_1000M_16PCS_3.zip
301 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR2_1G_1000M_16PCS_2.zip
298 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR2_1G_1000M_16PCS_1.zip
297 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR2_1G_1000_16PCS_4.zip
295 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR2_1G_800M_16PCS_J.zip
319 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR2_1G_800M_16PCS_I.zip
EK_DDR2_1G_800M_16PCS_H.zip
311 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR2_1G_800M_16PCS_G.zip
318 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR2_1G_800M_16PCS_F.zip
EK_DDR2_1G_800M_16PCS_B.zip
EK_DDR2_1G_800M_16PCS_C.zip
EK_DDR2_1G_800M_16PCS_D.zip
EK_DDR2_1G_800M_16PCS_E.zip
324 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
EK_DDR2_1G_667M_16PCS_1.zip
284 Bytes, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
