查看: 1821|回复: 1
清华同方超锐F5600问题
发表于 2011-11-10 18:04:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
开机出现
warning-cmos checksum invalid -run scuwarning-keyboard controller failure
base memory       0000640 kb
extended memory   1031168 kb
total memory      1032192 kb
shared memory     016384  kb
warning- no interrupts from timer 0
auto detecting ide devices[done]
press F2 to enter system configuration utility
initializing boot cd-rom - none
press F1 to continue
键盘用不了,南桥做了,BIOS也刷了,没思路了,请问各位高手怎么解决????
发表于 2011-11-10 18:29:07 | 只看该作者 �
键盘用不了你不查KBC换南桥干毛啊
