查看: 3714|回复: 6
CQ40 本本
发表于 2011-10-26 15:47:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
the system bios has detected your notebook pc was placed in hibernation to avoid overheating. the system is now operating normally and your data should remain intact
overheating may occur if the cooling vents are blocked or the operating temperature exceeds the specification. the notebook pc should return to normal operation once the situation is resolved.
system temperature (90D)
enter-continue startup
for more information,please visit:
风扇清过了  怎么解决
发表于 2011-10-26 15:59:21 | 只看该作者 �
好像就是风扇的问题
发表于 2011-10-26 16:41:46 | 只看该作者 �
温高报警
发表于 2011-10-26 17:59:14 | 只看该作者 �
换风扇就OK了
发表于 2011-10-26 18:36:25 | 只看该作者 �
看一下铜管是不是好的
发表于 2011-10-26 19:57:29 | 只看该作者 �
刷个BIOS看下
发表于 2011-10-26 19:59:36 | 只看该作者 �
看下温控模块是不是好的
