查看: 2653|回复: 3
[显卡维修]
帮忙看下1950GT 的R5MEMID1的测试结果
发表于 2011-2-10 18:00:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 河南郑州 来自 河南郑州
我倒第一次用R5检测显卡 可是怎么都看不懂 郁闷。。。。。。请问哪里是报错的脚位显示啊。
R5MEMID version 1.03, (c) Copyright ATI Technologies Inc, 2006
Log file generation enabled to .\R5MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
  [1] Mem production test FB001
    Failing Bits
      rk0 chA: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
      rk0 chB: 0 1 14 31
      rk0 chE: 4 6 7 8 9 10 11 13 14 16 17 18 19 20 21 22 23 24 26 27 28 29 30 31
      rk0 chF: 6 13
      rk0 chG: 2 4 5 6 9 10 11 14 16 17 18 27 28 30 31
      rk0 chH: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  [2] Mem production test FB063
    Failing Bits
      rk0 chA: 1 2 3 4 6 7 8 9 10 11 12 13 14 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
      rk0 chB: 0 31
      rk0 chE: 7 19 20 30 31
      rk0 chG: 9 30
  [3] Mem production test FB064
    Failing Bits
      rk0 chA: 0 1 2 3 6 7 8 9 10 11 12 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
      rk0 chB: 0 1
      rk0 chE: 7 19 20 31
      rk0 chG: 8 9 30
  [4] Mem production test FB065
    Failing Bits
      rk0 chA: 0 1 2 3 4 6 7 8 9 10 11 12 13 14 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
      rk0 chB: 0 31
      rk0 chE: 3 7 11 12 19 20 30 31
      rk0 chG: 9 18 25 30
  [5] Mem production test FB066
    Failing Bits
      rk0 chA: 1 2 3 5 6 7 8 9 10 11 12 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
      rk0 chB: 0 31
      rk0 chE: 3 7 12 19 20 31
      rk0 chG: 8 9 18 30
  [6] Modified FB088
    Failing Bits
      rk0 chB: 0
      rk0 chE: 7 9 11 14 16 20 26 30 31
      rk0 chF: 22
      rk0 chC: 21
      rk0 chG: 16 25
  [7] Modified FB091
    Failing Bits
      rk0 chB: 0
      rk0 chE: 7 9 11 14 16 19 20 26 30 31
      rk0 chF: 22
      rk0 chC: 20
      rk0 chG: 4 8 9 16 18
TEST RESULT SUMMARY:
RV570/M68 (0x7288) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Mem production test FB001                           : FAIL
    Error ID G0FB096
  1024 x  768 - argb8888 (60 Hz): TEST FAILURE
    Error count: total[16726849] chA[14785] chB[5] chE[249] chF[3] chG[127] chH[16711680]
[2  ] Mem production test FB063                           : FAIL
    Error ID G0FB096
    Error count: total[1048209] chA[1652] chB[3] chE[16] chG[10] chH[1046528]
[3  ] Mem production test FB064                           : FAIL
    Error ID G0FB096
    Error count: total[1047957] chA[1398] chB[3] chE[15] chG[13] chH[1046528]
[4  ] Mem production test FB065                           : FAIL
    Error ID G0FB096
    Error count: total[2096231] chA[3106] chB[8] chE[31] chG[30] chH[2093056]
[5  ] Mem production test FB066                           : FAIL
    Error ID G0FB096
    Error count: total[2096412] chA[3294] chB[4] chE[35] chG[23] chH[2093056]
[6  ] Modified FB088                                      : FAIL
    Error ID G0FB088
    Error count: total[113148] chA[14826] chB[1] chE[13] chF[1] chC[1] chG[2] chH[98304]
[7  ] Modified FB091                                      : FAIL
    Error ID G0FB091
    Error count: total[113410] chA[15080] chB[1] chE[18] chF[1] chC[1] chG[5] chH[98304]
Failure detected.
公版    正8个颗粒。
发表于 2011-2-11 15:57:47 | 只看该作者 来自: 台湾 来自 台湾
回复 自由如风 的帖子
通常那麼多錯誤點,我會先加焊GPU
发表于 2011-2-11 23:12:38 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
我修过蓝宝的x1950排列这个样子的
H G F E
             D
             C
             B
             A
发表于 2011-2-12 12:10:22 | 只看该作者 来自: 辽宁鞍山 来自 辽宁鞍山
先 修 A 通道
