查看: 12291|回复: 13
如何用“超级终端”修希捷硬盘?
发表于 2010-12-26 21:25:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
手头上有个希捷40G的硬盘,用MHDD修不了,erase不能通过。以前在论坛上看过相关用COM来修硬盘的资料,但是手上没有COM线,维修受到了限制;本来知道自己动手能力差,但还是硬给我做出了一条,虽然不怎么好看但是还能用....
接着打开超级终端,设定好参数后将COM连接主机与硬盘然后接上电源再点确定;一会儿有信息返还了,但是不知道该怎么操着,以上是硬盘给超级终端返还的信息:
AutoRd Err 47 at 00ec0c.00.0002
AutoRd Err 43 at 00ec0c.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Master with Non-conforming Slave
AutoRd Err 47 at 00ec0c.00.008b
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AT Er 00 Nwt Er 43 RdWr 0018.00.0000
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot:  4070e7e2  ff  0000e7e2.4070.000 00db 0000  e6b0 0001
AutoRd Err 43 at 000018.00.003f
CE Log EC=43  Rtype=25 OV=0 STStatus0
AutoRd Err 43 at 00ec0c.00.008b
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
SCAN Error
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
CE Log EC=43  Rtype=26 OV=0 STStatus0
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Not handled software path: &L&L&
AT Er 00 Nwt Er 00 RdWr ec0c.00.0000
CE Log EC=43  Rtype=24 OV=0 STStatus0
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AT Er 00 Nwt Er 47 RdWr 0021.00.0000
AutoRd Err 47 at 000021.00.00bb
CE Log EC=47  Rtype=25 OV=0 STStatus0
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
SCAN Error
到这里就停了.....无从下手,原谅我是新手,请求详细解答..
附图:
追加:是不是出现这种情况无法用超级终端修复?
发表于 2010-12-26 21:29:12 | 只看该作者 �
还有是不是要接上IDE口呢? 沙发..
发表于 2010-12-26 21:30:00 | 只看该作者 �
固件区有坏,头也可能坏,,40G就不要太浪费时间了。
发表于 2010-12-26 21:32:43 | 只看该作者 �
回复 快乐皮皮 的帖子
这个盘可以用来学习,会的话请教一下吧
发表于 2010-12-26 21:42:15 | 只看该作者 �
好像各位都嫌这硬盘容量太小不肯教呀{:3_65:}
发表于 2011-1-8 10:52:51 | 只看该作者 �
先输入N2,,22回车,然后再CTRL +T,不过好像也没什么作用,如果自检不能通过的话,连认盘都成问题。
发表于 2011-1-8 19:12:05 | 只看该作者 �
COM下只能看信息要修的话你可以下载个破解的春华
发表于 2011-1-10 12:35:44 | 只看该作者 �
这是ST盘的通病,43,47报错
你可以I,,22
或者N02,AA,22命令30秒看看,不行就SF吧
发表于 2011-1-12 16:04:40 | 只看该作者 �
请问下COM口和硬盘怎么连接?最好能上个图
另:请问7楼老师破解版的春华是什么软件?可以给个下载地址么?
头像被屏蔽
10#
发表于 2011-1-12 18:35:25 | 只看该作者 �
希捷的盘不是光用com线的,你没有相关的软件最好不要SF ,没有备份固件做完也没用。
发表于 2011-1-12 18:54:24 | 只看该作者 �
使用I ,,22 N2,,22 等..需备份ATA ....免得不认盘..上面有几楼的.真够黑心...明知道别人是新手.不告诉它备份 ATA.
发表于 2011-1-16 21:27:49 | 只看该作者 �
回复 东方电脑维修 的帖子
摸出点头绪了,不过春华的P解版好像连个固件都备份不了,一备份就程序假死
发表于 2011-1-16 21:28:34 | 只看该作者 �
回复 义气登堂 的帖子
还是这位大哥贴心
发表于 2011-1-17 08:48:09 | 只看该作者 �
回复 intelzx 的帖子
pc 3k, test heads and fw
