查看: 7286|回复: 3
求购HP V3700 bios
发表于 2010-8-31 10:20:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
求购HP V3700 bios    V3802TX谢谢
发表于 2010-8-31 10:22:09 | 只看该作者 �
官方网站有的下的,www.hp.com
发表于 2010-9-1 11:36:39 | 只看该作者 �
官方的不能用编程写,写了没有用的要分离之后的才可以。
发表于 2010-9-3 23:23:58 | 只看该作者 �
HP网上放了两个,几乎同一日期的。第一个写着AMD处理器,第二个没说CPU的事。
您自己找个合适的,用WINRAR解压缩吧。
» WinFlash for HP Notebook System BIOS (for Notebooks with AMD Processors) - Microsoft Windows/Vista-Based
2008-12-22 , Version:F.27, 4.26M (‏revious versions available)‏
This package contains the WinFlash utility and a System BIOS image for the supported notebook models and operating systems. The WinFlash utility is used to locally flash the System BIOS (ROM) on notebooks operating in a Microsoft Windows or Microsoft Windows Vista environment.
More info
Download »
» WinFlash for HP Notebook System BIOS - Microsoft Windows Vista Based
2008-12-15 , Version:F.2E, 3.93M (‏revious versions available)‏
This package contains the WinFlash utility and a System BIOS image for the supported notebook models (both 30CD and 30CE Family ROM) and operating systems. The WinFlash utility is used to locally flash the System BIOS (ROM) on notebooks operating in a Microsoft Windows Vista environment.
