查看: 1908|回复: 2
hp dv5 amd
发表于 2010-8-18 03:33:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
hello,
there is a common problem with hp dv5 amd laptops with amd ati chipset.the error code blinking is 2 times which means bios but i reprogrammed the bios 2 times and same problem i read on the manual for hard reset the laptop the display came oncce again same problem does anyone know abut the dv5 and cq40, all same problems.
thanks
发表于 2010-8-18 07:02:21 | 只看该作者 �
DV5 和CQ系列是HP给我们的又一笔好生意,看来通病不少。现在很多机器都过保修期了,显卡、北桥的问题都开始出来了,建议大家多关注一下。LZ如果写中文的话可能得到的回复会多一点吧。
发表于 2010-8-18 10:23:31 | 只看该作者 �
We generally use the current meter or an oscilloscope to judge failure
