查看: 2880|回复: 8
[显卡维修]
9800se花屏,请指点一下
发表于 2010-8-10 17:39:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 河北石家庄 来自 河北石家庄
今天收到一块9800se,花屏。第一次尝试修显卡,下了r3,测试结果如下,请帮忙分析一下该从哪里下手,已经加焊正反8个显存,显存周边的排阻也检测过了正常。该从哪里下手呢?
发表于 2010-8-10 17:39:54 | 只看该作者 来自: 河北石家庄 来自 河北石家庄
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDC0 34 56 57 58 59 60 61 62 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDC0 0 1 2 3 4 5 6 7 ... MDD0 0 1 2 3 4 5 6 7 ...
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
    failing bit : MDC0 3 4 5 6 7 8 9 10 ... MDD0 3 4 5 6 8 9 10 11 ...
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
    failing bit : MDC0 3 4 5 7 8 9 10 11 ... MDD0 3 4 5 6 7 8 9 10 ...
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
TEST RESULT SUMMARY:
R350 (0x4148) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
    Error ID G0VB023
    Error ID G0VB024
    Error ID G0VB025
    Error ID G0VB028
    Error ID G0VB006
    Error ID G0VC006
    Error ID G0VC009
    Error ID G0VC018
    Error ID G0VC021
    Error ID G0VC052
    Error ID G0VC057
    Error ID G0TR055
    Error ID G0TR014
    Error ID G0TR010
Failure detected.
发表于 2010-8-10 23:01:42 | 只看该作者 来自: 浙江杭州 来自 浙江杭州
一代的显存容易坏先把左边后面的那个换了先再测
发表于 2010-8-10 23:43:16 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
核心空焊的可能性最大
发表于 2010-8-11 00:44:29 | 只看该作者 来自: 上海浦东新区 来自 上海浦东新区
住芯片  坏了  和颗粒无关
发表于 2010-8-11 01:28:02 | 只看该作者 来自: 河南南阳 来自 河南南阳
核心从做.如果还不好的话,就好核心挂了
发表于 2010-8-11 12:48:19 | 只看该作者 来自: 广东佛山 来自 广东佛山
这样花的我一般不修了 不是显存坏就是GPU要换、重值.....
发表于 2010-8-11 20:10:52 | 只看该作者 来自: 河北石家庄 来自 河北石家庄
今天试了加焊GPU,花屏更加严重了。这两天忙,等抽空再搞搞它,不行就当料板了。谢谢各位帮忙指点!!
发表于 2010-8-18 09:11:10 | 只看该作者 来自: 广东珠海 来自 广东珠海
GPU 虚焊 80%
