查看: 2052|回复: 4
VFAN CONTROL IDEA COMPAQ V3000
发表于 2010-8-1 22:16:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
i get idea from here thank you for good knowledge thank you very much.If i have wrong can advice and tell me.
today i read laptop discussion about fan voltage control,sorry i forget link topic.
Compaq V3000 SHIBA model gpu heat-cycle fail.I chang a new gpu 6150.OK it's work and then i try to modify my fan voltage.I want to adjust VFAN for 3.3 volt when start and when it's hot just rise up to 5v becouse if i use only 5v all time it's noisy and loud.that can see photo below.That's ok.Thanks for Chinafix about good idea,thanks again.
***i don't know how to upload photo.I try and fail.***
发表于 2010-8-1 22:31:17 | 只看该作者 �
论坛里还有外国朋友啊,在下外语从小就没学好,说的什么实在是不知道
帮楼主顶下
发表于 2010-8-1 23:20:45 | 只看该作者 �
有人会翻译吗。。
发表于 2010-8-1 23:23:48 | 只看该作者 �
就是之前有朋友发过的一个风扇方案。高温用5V。低温3。3V。两个电压用二极管隔离。楼主,换芯片吧。这法也不靠谱的。
发表于 2010-8-2 00:25:02 | 只看该作者 �
我觉得V3000的风扇5V都转得太慢,还搞什么3.3V?
