查看: 1965|回复: 7
[显卡维修]
麻烦大家帮忙分析下测试结果,9550 128M的卡
发表于 2010-3-20 11:47:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...Failing bits in test [1] Fill
  errcount: 12641213
  MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [1] Fill
  errcount: 12961776
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [2] Data line toggle (GUI)
  errcount: 6157716
  MDA0: 16 17 18 19 20 21 22 23
  MDB0: 20 21 48 49 50 51 52 53 54 55Failing bits in test [3] RW page (GUI)
  errcount: 16458022
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [4] RW channel (GUI)
  errcount: 9447887
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [5] Data mask
  errcount: 10501496
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [6] Macro + Micro8x2 tiling read
  errcount: 3395414
  errcount: 3390693
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [7] Byte swap macro+micro8x2 read
  errcount: 25773289
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [8] HOST_DATA/<f,b>/M2L
  errcount: 2472
  MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 49 50 52 53 55
  MDB0: 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55Failing bits in test [8] HOST_DATA/<f,b>/M2L
  errcount: 8706
  MDA0: 16 17 18 19 20 21 22 23 50 52 55
  MDB0: 16 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55Failing bits in test [8] HOST_DATA/<f,b>/M2L
  errcount: 9398
  MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  errcount: 15845
  MDA0: 16 17 18 19 20 21 22 23 49 50 51 52 55
  errcount: 7608
  MDA0: 16 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55
  errcount: 13238
  MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 48 49 50 51 52 53 54 55
  MDB0: 17 18 20 21 22 23 48 49 50 51 52 53 54 55Failing bits in test [8] HOST_DATA/<f,b>/M2L
  errcount: 15163
  errcount: 23489
  errcount: 13818
  MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 49 50 51 52 53 54 55
  errcount: 22535
  MDA0: 0 1 2 3 4 5 6 7 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 50 52 55
  MDB0: 18 20 21 22 23 49 50 51 52 53 54 55Failing bits in test [8] HOST_DATA/<f,b>/M2L
  errcount: 27377
  errcount: 53156
  MDA0: 1 2 3 4 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 33 34 35 36 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  MDB0: 1 2 3 4 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 33 34 35 36 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55Failing bits in test [9] Line slopes/dir/P/solid
  errcount: 2260
  MDA0: 16 17 18 19 20 21 22 23 49 50 52 53 54 55 56 58 59 60 61 62 63
  MDB0: 17 18 20 21 22 23 48 49 50 51 52 53 54 55Failing bits in test [9] Line slopes/dir/P/solid
  errcount: 6445
  MDA0: 16 17 18 19 20 21 22 23 56 57 58 59 60 61 62 63
  MDB0: 16 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55Failing bits in test [9] Line slopes/dir/P/solid
  errcount: 7209
  errcount: 9284
  MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55
  errcount: 5136
  errcount: 8743
  MDA0: 16 17 18 19 20 21 22 23 50 52 55 56 57 58 59 60 61 62 63
  errcount: 8781
  errcount: 12242
  errcount: 9196
  MDA0: 16 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55 56 58 59 60 61 62 63
  errcount: 9985
  errcount: 393216
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [9] Line slopes/dir/P/solid
  errcount: 786432
TEST RESULT SUMMARY:
发表于 2010-3-20 11:48:43 | 只看该作者 �
Rv350 (0x4153) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
    failing bit : MDA0 16 17 18 19 20 21 22 23 MDB0 20 21 48 49 50 51 52 53 ...
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 17 18 19 20 21 22 23 48 ...
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 16 17 18 19 20 21 22 23 ... MDB0 16 17 18 19 20 21 22 23 ...
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 16 17 18 19 20 21 22 23 ...
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 16 17 18 19 20 21 22 23 ... MDB0 17 18 19 20 21 22 23 48 ...
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 17 18 20 21 22 23 48 49 ...
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 18 20 21 22 23 49 50 51 ...
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 1 2 3 4 7 8 9 10 ... MDB0 1 2 3 4 7 8 9 10 ...
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
    failing bit : MDA0 16 17 18 19 20 21 22 23 ... MDB0 17 18 20 21 22 23 48 49 ...
Failure detected.
发表于 2010-3-20 12:28:26 | 只看该作者 �
全部报错,先换AB通道首颗显存试试~
发表于 2010-3-20 13:15:35 | 只看该作者 �
请问怎么定位AB通道首颗显存?
发表于 2010-3-20 14:02:59 | 只看该作者 �
正面下向上第一第三颗的对应的背面一颗 为A和B通道首颗
发表于 2010-3-20 23:47:13 | 只看该作者 �
电压 正常?  核心有无损坏  ,  地址线以及其他显存公用线,对地阻值 有没有 异常
发表于 2010-4-18 23:58:31 | 只看该作者 �
板主,谢谢你的回答,但我刚学维修,
请问你说的地址线在那里,还有着手修理一张花屏的显卡开始最先应该测量一些什么关键值呢?
还有一个问题,请问一张花屏的显卡如果任意拆掉一个显存,而原来花屏的样子没有变化,说明什么呢?
发表于 2010-4-25 18:49:51 | 只看该作者 �
那只能说明故障点并不是拆掉的那个显卡上
