查看: 2341|回复: 6
[显卡维修]
一块小影霸9550 256M的显卡大花
发表于 2010-2-8 09:39:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 河南漯河 来自 河南漯河
一块小影霸9550 256M的显卡大花,盲测结果如下:
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 0 1 2 3 4 5 6 7 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.8 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.8 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.8 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.8 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.8 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.8 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.8 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.8 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.8 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.8 not found
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.8 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.8 not found
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
     error : R051A.9 not found
     error : R052A.9 not found
     error : R053A.9 not found
     error : R055A.9 not found
     error : R061A.9 not found
     error : R062A.9 not found
     error : R063A.9 not found
     error : R065A.9 not found
     error : R071A.9 not found
     error : R072A.9 not found
     error : R073A.9 not found
     error : R075A.9 not found
Failure detected.
根据测试的结果,判断为U9出错,换U9后上机还是大花,测试和前一样,考虑是不是换上去的是坏的,又换了一次。检测结果还是和先前一样的结果,迷惑中,是定位错误还是主芯片虚焊,外围也查了吗、,愿各位版主及各位朋友给一指点?在线。。。
发表于 2010-2-8 10:19:48 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
看图片你应该把U9加焊过了,实在不行就把B通道的显存全拆下,然后刷256M64B的BIOS
发表于 2010-2-8 11:43:55 | 只看该作者 来自: 四川眉山 来自 四川眉山
如果是盈通的9550,没有风扇的那种主芯片很容易坏,容易压裂桥板。
发表于 2010-2-8 12:39:21 | 只看该作者 来自: 河南漯河 来自 河南漯河
是的,U9已经换过两次了。故障依旧。那就照版主的做做试一试
发表于 2010-2-8 18:02:28 | 只看该作者 来自: 江苏苏州 来自 江苏苏州
你 放弃吧,如果是核心坏了,这种板型 没有64b的 BIOS
至少论坛没有
发表于 2010-2-8 23:19:39 | 只看该作者 来自: 山东潍坊 来自 山东潍坊
我手头有N片跟楼主一模一样的显卡,是去年缺煤缺电的时候电压不稳造成的。我不懂显卡。但是我觉得应该换个方向。
发表于 2010-2-11 13:06:23 | 只看该作者 来自: 上海浦东新区 来自 上海浦东新区
{:3_46:} 怪不得我的那块改了64位后还是花屏,原来还是bios的问题,一直以为B区坏的严重,影响A区呢,看来不是什么卡都能改64位的。谢谢了。
