- 积分
- 7
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2009-8-3
- 精华
Customer brought a Compaq 6715b Notebook that had fell on the floar. There was no light light on screen, but you could see dark picture in the background. I connected another lcd screen and it was working fine. I took out good CCFL lamp from broken LCD display (same size, but different manufacturer). It took a long time to carefully dissasemble LCD screen, clean the broken glass particles and reassemble everything back. I was realy happy to see that everything is working fine when I put it back together .
顾客带来了康柏6715b笔记本电脑已经在floar下跌。目前还没有银幕之光灯,但你可以看到黑暗背景图片。本人有关联的另一个液晶屏幕和它工作正常。我拿出来自破碎液晶显示器好CCFL灯管(大小相同,但不同的制造商)。它花了很长时间,仔细dissasemble液晶屏幕,清理碎玻璃微粒和重新组合的一切回来。我真的很高兴地看到,一切工作正常,当我把它重新走到一起。 |
