查看: 2969|回复: 8
[显卡维修]
两张9550 R3检测结果,那颗显存坏?
发表于 2009-10-8 04:44:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
第一张:两128的9550显卡 R3检测结果如下:
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
RV350/M10 (0x4150) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 34 MDB0 33 35 52 54
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : PASS
[12 ] Macro+Micro4x4 alignment read                       : PASS
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST PASSED
Failure detected.
第二张:128bit 256M 9550
RV350/M10 (0x4153) detected.
256M video memory.
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1280 x 1024 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 2 34 MDB0 32 33 50 51 52 53 54 55 ...
[2  ] Data line toggle (GUI)                              : PASS
    Error ID G0VB024
    Error ID G0VB025
    Error ID G0VB028
    Error ID G0VB006
    Error ID G0VC006
    Error ID G0VC009
    Error ID G0VC018
    Error ID G0VC021
    Error ID G0TR055
    Error ID G0TR014
    Error ID G0TR010
Failure detected.
发表于 2009-10-9 12:39:13 | 只看该作者 �
背面下数第一颗
发表于 2009-10-10 01:09:35 | 只看该作者 �
谢谢一会试一下看看。
发表于 2009-10-11 02:04:58 | 只看该作者 �
两张显卡均修好了。第一块坏了背面上往下数第一颗 第二张是背面上往下数第一颗和第二颗。谢谢新诚达
发表于 2009-10-11 10:05:01 | 只看该作者 �
两个区同时坏的基本都是GPU坏了
头像被屏蔽
6#
发表于 2009-11-23 13:58:05 | 只看该作者 �
在次顶...大家上啊。
发表于 2009-11-26 13:36:07 | 只看该作者 �
反面下数第一颗 第二颗      反面上边左边一颗
发表于 2010-1-5 16:59:42 | 只看该作者 �
A面下数第一颗和B面下数第一颗!
发表于 2010-1-5 17:12:10 | 只看该作者 �
B的是在背面上面右边那个.
