查看: 833|回复: 0
[维修资料]
CP TOOL解锁小米红米BL 工具 CPT PRO TOOL
发表于 2026-9-26 10:22:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Update Notes[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥 CPTool 1.6.2 Update Released !
[size=1.1]
🔥 Kernel Exploit Android 14 /15 Improved
  • Redmi Note 15 4G (spinel)
  • Redmi Note 14 Pro (obsidian)
  • Redmi Note 14 4G (tanzanite)
  • Redmi Note 13 Pro 4G (emerald)
  • Redmi Pad 2 4G (koto)
  • Xiaomi 13T (aristotle)
  • Redmi K50 (rubens)
Xiaomi 17T Pro (warhol) Patch Cert Fixed
Optimized Meta Mode
Optimized Light Theme
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥CPTool 1.6.1 Update Released !
[size=1.1]
⭐️Minor bugs fixed
⭐️Added & Optimized Some Device's
🔥Kernel Exploit New Models Improved
  • Xiaomi Redmi Note 12R (sky)
  • Xiaomi Redmi Note 12 5G  (sky)
  • POCO M6 Pro 5G (river)
  • Redmi 12 5G (XIG03)
  • Xiaomi 15 (dada)
  • Xiaomi 15 Pro (haotian)
  • Xiaomi 15 Ultra (xuanyuan)
  • Pad 8 Pro (piano)
  • Redmi Note 14 Pro+ (amethyst) OS1 Optimized
  • Redmi Note 15 Pro+ 5G (flourite) OS2 Optimized
  • Redmi Note 13 Pro 5G (garnet) OS1 Optimized
  • Redmi Note 15 Pro (lapis) Android 14 Optimized
⭐️ Added Latest Security Android 17 Google Pixel Root Files
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥CPTool 1.6.0 Update Released !
[size=1.1]
🔥Added Manuel Timer Selection (Kernel Exploit)
  • Xiaomi 15T (goya) *tested*
  • Redmi K70 Ultra (rothko) *tested*
  • POCO X6 Pro 5G (duchamp) *tested*
  • Note 14 Pro/POCO X7 (malachite) *tested*
  • Xiaomi 14T (degas)
  • Xiaomi 15 (dada)
Added Qualcomm Bootloader Unlock (*kernel exploit need)
Improved Bootloader Unlock (charoite / duchamp / degas etc. )
Fixed MTK V5 Connect Bugs
Added New Spreadtrum V2 Payloads
Fixed ADB handshake bugs
Improved Flash / ADB mode Patch BL Lock Option
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥CPTool 1.5.9 Update Released!
[size=1.1]🔥Added Bootloader Lock Temp Root Following Models
  • Xiaomi 17T Pro (warhol)
  • Xiaomi 17T (chagall)
  • Xiaomi 17 Ultra (nezha)
  • Xiaomi 17 (pudding)
  • Xiaomi 17 Pro (pandora)
  • Xiaomi 17 Pro Max (popsicle)
  • POCO F8 Ultra (myron)
  • Redmi K90 Pro Max (myron)
  • Redmi Turbo 5 (klee)
  • Redmi K80 Ultra (dali)
  • POCO X8 Pro (klee)
  • Redmi Turbo 5 Max (dash)
  • POCO X8 Pro Max (dash)
  • Xiaomi 15T (goya)
  • Redmi Turbo 4 (rodin)
  • Redmi Note 15 Pro 4G (chaorite)
  • Redmi Note 14 Pro 4G (obsidian)
⭐️Device MUST BE ANDROID 16 !
⚠️OLD MODELS NOT SUPPORTED BY KERNEL VERSION-!
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]CPTool 1.5.8 Update Released! [Patch Bootloader Lock NEW]
[size=1.1]
⭐️ Added Patch Bootloader Lock NEW [Xiaomi] All Mediatek !!!
Now you will be able to seamlessly perform Bootloader Lock IMEI Repair operations on all Xiaomi MediaTek devices from the past to the present.
✅ Old gen Xiaomi MTK devices
✅ New gen Xiaomi MTK devices
✅ No Camera problems
✅ No Flash/SMS problems
✅ Factory Reset
❌ OTA UPDATE
Some tested devices;
  • Xiaomi 17T Pro (warhol) Tested
  • Xiaomi 17T (chagall) Tested
  • Redmi Note 15 Pro (lapis) Tested
  • Redmi Note 15 Pro 4G (charoite) Tested
  • Redmi Turbo 5 / POCO X8 Pro (klee) Tested
  • Redmi Turbo 5 Max / POCO X8 Pro (dash) Tested
  • Xiaomi 15T Pro (klimt) Tested
  • Xiaomi 15T (goya) Tested
  • Redmi Note 14 Pro 4G GLB (obsidian) Tested
  • Xiaomi Redmi K70E / X6 Pro 5G  (duchamp) Tested
  • Redmi Note 14 4G (tanzanite) Tested
  • Redmi Note 13 Pro 4G/POCO M6 Pro (emerald) Tested
  • Redmi Turbo 4 (rodin) Tested
  • Redmi 15C / POCO C85 (dew) Tested
  • Redmi 13C/POCO C65 (gale/gust) Tested
  • Redmi 14C / C75 / A3 Pro (pond) Tested
  • Redmi A3 (moon) Tested
  • Redmi 13C 5G (air) Tested
  • Note 13 5G / 13R Pro (gold) Tested
  • Redmi A3 (blue) Tested - NO CAMERA ISSUE
  • Redmi Note 9/Redmi 10X 4G (merlin) Tested
  • Redmi 9 (lancelot) Tested
  • Redmi Note 8 Pro (begonia) Tested
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥CPTool 1.5.7 Update Released!
[size=1.1]
  • Added Samsung ODIN Multi Flash Support
  • Added Exit Factory Mode [Xiaomi Qualcomm]
    Now you can exit EDL Mode 1 Click.
    No need flash full firmware !
  • Optimized Qualcomm EDL
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥 CPTool 1.5.6 Update Released!
[size=1.1]
⭐️Added Xioami Free Fastboot to EDL
⭐️Added Manuel Unlock Bootloader Option [Mediatek]
⭐️Added Xiaomi Qualcomm Permanent Unlock Bootloader
  • Xiaomi Turbo 4 Pro (onyx)
  • Xiaomi CIVI 5 Pro (luming)
  • Xiaomi Pad 8 (yupei)
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥CPTool 1.5.5 Update Released!
[size=1.1]😍Added Mediatek Bootloader Unlock 🔥
  • Xiaomi Redmi K70E (duchamp) Tested
  • POCO X6 Pro 5G (duchamp) Tested
  • Redmi Note 14 Pro 4G (obsidian) Tested
⭐️Added Oppo / Realme OFP Flash
⭐️Added Mediatek V5/V6 Flash Protocol
⭐️GUI Optimised
👀Warning ! Unlock Bootloader NOT PERMANENT !
When flash new fw / OTA Update Relock Again !
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥CPTool 1.5.4 Update Released!
[size=1.1]😍Qualcomm PERMANENT Bootloader Unlock New Models 🔥
  • Xiaomi CIVI 4 Pro (chenfeng)
  • Xiaomi 14 CIVI (chenfeng)
  • Redmi Turbo 3 (peridot)
  • Xiaomi Poco F6 (peridot)
  • Xiaomi Pad 7 Pro (muyu)
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥CPTool 1.5.3 Update Released!
[size=1.1]
  • Xiaomi 14 Pro (shennong)
  • Xiaomi 14 Ultra (aurora)
  • Xiaomi 14 (houji)
  • Mix Fold 4 (goku)
  • Mi Mix Flip (ruyi)
  • Redmi K80 (zorn)
  • POCO F7 Pro (zorn)
  • Redmi K70 Pro (manet)
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥CPTool 1.5.2 Update Released!😍 [Remove MI ID Permanent]
[size=1.1]🔥Added Remove Mi Account PERMANENT !
🔥Added Disable Update PERMANENT !
🔥UPDATE & Factory Reset No Lock Again !
🔥You Can Login New Mi Account !
🔥After Wipe No Relock !
🔥After Update No Relock !
🔥No Bla Bla ! Yes CPTOOL 🔥🔥🔥
Added Following Models
  • Redmi 15C (tornado)
  • Redmi 15R 5G (tornado)
  • Xiaomi 15T (goya)
  • Redmi 14C (pond)
  • POCO C75 / A3 Pro (lake)
  • Redmi 12 (fire)
  • Redmi 12C (earth)
  • Xiaomi 13T Pro/Redmi K60 Ultra (corot)
  • Xiaomi 11T (agate)
  • Xiaomi 12T (plato)
  • Redmi Note 13 Pro+(zircon)
  • Redmi Note 11T Pro/Pro+/POCO X4 GT (xaga)
  • Redmi K50i (xaga)
  • Redmi Note 13 5G (gold)
  • Redmi Note 13R Pro (iron)
  • Redmi A3 (blue)
  • Redmi A3 (moon)
  • Redmi 13 (tides)
  • Redmi 13x (tides)
  • Redmi A2 / A2(water)
  • Redmi A1 / A1(ice)
  • Redmi 10/10 Prime (selene)
  • Redmi Note 11 4G (selenes)
  • Redmi Note 11 Pro 4G(viva/vida)
  • Redmi Note 11 Pro+(pissarropro)
  • Redmi Note 11 Pro / Xiaomi 11i 5G (pissarro)
  • Redmi Note 12S (sea/ocean)
  • Redmi Note 12 Pro 5G (ruby)
  • Redmi Note 12 Pro5G (rubypro)
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥CPTool 1.5.1 Update Released!😍
[size=1.1]
Added Following Models Unlock Bootloader Permanent!
  • Redmi 15 (creek)
  • Poco M7 (creek)
  • Redmi 14R 5G (flame)
  • Redmi 14C 5G (flame)
  • Redmi Note 13 (sapphire)
  • Redmi Note 13 NFC (sapphiren)
  • Redmi Note 12 4G (tapas)
  • Redmi Note 12 4G (topaz)
  • Redmi Note 13R (breeze)
  • Redmi Note 13 5G (breeze)
  • POCO M6 Plus 5G (breeze)
  • Redmi Note 12R (sky)
  • Redmi Note 12 5G (sky)
  • Poco M6 Pro 5G (river)
  • Redmi Note 11 (spes)
  • Redmi Note 11 IN (spesn)
  • Redmi 10C (fog)
  • Redmi 10C (rain)
Added Loader Following Models
Flash / Frp / Read - Wipe EFS / Partition Manager
Xiaomi
  • Xiaomi 15 Pro (Haotian)
  • Xiaomi 15 Ultra (Xuanyuan)
  • Xiaomi 15 (Dada)
  • Mix Flip 2 (Bixi)
  • Pad 8 Pro (Piano)
  • Redmi K80 Pro (Miro)
  • Redmi K90 / POCO F8 Pro (Annibale)
ZTE
  • Redmagic 10 Air Series (NP03J)
  • Redmagic 10 Series (NX779J)
  • Redmagic 9 Series (NX769J)
  • Redmagic 8 Series (NX729J)
  • Redmagic 7 Series (NX679J)
  • Redmagic 6 Series (NX666J)
  • Redmagic 5 Series (NX659J)
  • Z60 Ultra Series (NX721J)
Lenovo
  • Legion Duel (L79031)
  • Legion 2 (L70081)
  • Legion Y90 (L71061)
Nothing Phone
  • Phone 1 (20111)
  • Phone 2 (23112)
  • Phone 3 (23112)
Improved Read EROFS Qualcomm 9008 Support
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥 CPT V1.5.0 Update Released 😍
[size=1.1] Qualcomm PERMANENT Bootloader Unlock – New Models
(* PERMANENT UNLOCK) 🔥
  • Xiaomi 13 Ultra (ishtar) *
  • Xiaomi 13 Pro (nuwa) *
  • Xiaomi 13 (fuxi) *
  • Mix Fold 3 (babylon) *
  • Xiaomi Redmi K70 (vermeer) *
  • POCO F6 Pro (vermeer) *
  • Redmi K60 Pro (socrates) *
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥 CPT V1.4.9 Update Released 😍
[size=1.1] Xiaomi
  • Added Fastboot GPT Flash
  • Added New No Root Diag Mode Instruction (aurora, amethyst, sapphire etc.)
  • Added Mi Asistan Mode
    • Factory Reset
    • Wipe EFS
  • Added Bootloader Unlock Temp Support
    • Redmi Note 13 (sapphiren)
Google Pixel
  • Added Google Pixel 10a (stallion) Support
  • Automatic Root & Unroot
  • Repair IMEI
  • Network Unlock
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]CPT V1.4.8 Update Released 🚀
  • Xiaomi 15 Ultra (xuanyuan) *
  • Xiaomi 15 Pro (haotian) *
  • Xiaomi 15 (dada) *
  • Redmi K90 (annibale) *
  • Poco F8 Pro (annibale) *
  • Redmi K80 Pro (miro) *
  • Xiaomi MIX Flip 2 (bixi) *
  • POCO F8 Ultra (myron) *
  • Redmi K90 Pro Max (myron) *
  • Mix Fold 4 (goku)
  • Mix Fold 2 (zizhan)
DIAG MODE
  • Added NV Method
  • Added NV Method (Resistant)
  • Added Qualcomm Generic Method
  • Added ZTE Redmagic Method
  • Added QCN Editor
  • Added xQCN Editor
  • Added HyperOS 3 Diag Mode
EDL MODE – Improved Xiaomi EDL Authentication Support
  • Redmi Note 12 Pro 4G (sweet_k6a)
  • Black Shark 4, Black Shark 4S (penrose)
  • Black Shark 4 Pro, Black Shark 4S Pro, Black Shark 5 RS (kaiser)
  • Black Shark 5 (patriot)
  • Black Shark 5 Pro (katyusha)
  • Mi 8 Lite (platina)
  • Mi 9, Mi 9 Explorer (cepheus)
  • Mi 9T, Redmi K20 (davinci)
  • Mi 9T Pro, Redmi K20 Pro (raphael)
  • Mi 10 (umi)
  • Mi 10T 5G, Mi 10T Pro, Redmi K30S (apollo)
  • Mi 11 (venus)
  • Mi 11 Lite (courbet)
  • Mi 11 Lite 5G (lisa)
  • Mi 11 Pro, Mi 11 Ultra (star)
  • Mi 11i, POCO F3 Pro, Redmi K40 Pro, Redmi K40 Pro+ (haydn)
  • Mi 11X, POCO F3, Redmi K40 (alioth)
  • Mi A2 (jasmine)
  • POCO M2 Pro (gram)
  • POCO X3 NFC (surya)
  • POCO X3 Pro, Redmi Note 10 Pro (chopin)
  • Redmi 7A (pine)
  • Redmi 8 (olive)
  • Redmi 10, Redmi 10 Power, Redmi 10C (fog)
  • Redmi Note 5 AI Dual Camera, Redmi Note 5 Pro (whyred)
  • Redmi Note 6 Pro (tulip)
  • Redmi Note 7, Redmi Note 7S (lavender)
  • Redmi Note 8 (ginkgo)
  • Redmi Note 8T (willow)
  • Redmi Note 9 Pro (joyeuse)
  • Redmi Note 9 Pro Max (excalibur)
  • Redmi Note 9S, Redmi Note 10 Lite (curtana)
  • Redmi Note 10 (mojito)
  • Redmi Note 11 NFC (spesn)
  • Redmi Y3 (onc)
FLASH MODE
  • Added 9008 Flash Firmware
  • Sahara V3 Protocol improved
  • Added AutoDetect EMMC/UFS Chip Select
  • XML Protocol upgraded
Google Pixel
  • Added more than +100 Automatic Root
  • Added Pixel Network Unlock FREE
  • No need credits & no need firmware
MTK
  • Added Infinix / Itel / Tecno V6 2025.11 DA's
  • Fixed some connection bugs
Samsung
  • Fixed EUB bugs
ADB
  • Fixed some bugs
  • Upgraded CPTool Disk Manager 1.5
GUI
  • Fixed some bugs
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(40, 167, 69) !important]🔥 CPT V1.4.7 Update Released 😍
[size=1.1] New Device Support
  • Redmi Note 15 4G (spinel) – Patch Bootloader Lock Added
  • Redmi Note 13 Pro+ (zircon) – HyperOS 3.0 Patch Bootloader Lock Added
New Features
  • Critical Info Parser Protocol Added
  • You can verify CTA / IMSI / Product Code directly from critical file
Tools
  • FREE IMEI / FSN / SN Checker Added
  • Now you can check original IMEI status
Fixes
  • Fastboot flash bugs fixed
[backcolor=rgb(31, 36, 43) !important][backcolor=rgb(220, 53, 69) !important]🔥 CPT V1.4.4 Update Released! [Xiaomi Qualcomm Bootloader Unlock] 😍
[size=1.1] Major Feature
  • Xiaomi Qualcomm Bootloader Unlock Added
  • No Need EDL / No Need Auth
  • Supports Hyper OS1 / OS2 / OS3
  • Security Patch Must Be Before 02.2026
Supported Models
  • Xiaomi 17 Ultra (nezha) *
  • Xiaomi 17 (pudding) *
  • Xiaomi 17 Pro (pandora) *
  • Xiaomi 17 Pro Max (popsicle) *
  • Xiaomi 15 (dada)
  • Xiaomi 15 Pro (hacitan)
  • Mix Fold 4 (goku)
  • MIX Flip (ruyi)
  • Xiaomi 14 (houji)
  • Redmi K70 (vermeer)
  • Redmi KW Pro (miro)
  • Redmi K80 (zorn)
  • Xiaomi CIVI 4 (chenfeng)
