查看: 210|回复: 3
[智能电视]
SUNNY Android TV
发表于 2026-9-8 02:02:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
my friend
SUNNY Android TV
SUNNY SN49DAL27\0216
TRSNDLD049250100011962
No picture; the backlight LEDs are on, and the standby light is flashing.
I need the firmware and software for the eMMC, information on which program/tool ?to use to flash the eMMC, and a connection diagram.
How do I connect and perform an upgrade on this setup using an RT809H or eMMC?
thanks
发表于 2026-9-8 09:11:27 | 只看该作者 �
那不是电阻,是颗电容。
发表于 2026-9-9 12:01:42 | 只看该作者 �
直接换板七八百,NO thanks
发表于 2026-9-10 00:43:48 | 只看该作者 �
Mate, these devices can be brought back to life by flashing software; I need the pinout diagrams for the RT809H to program the eMMC chip—whether via USB or through the programmer's ports.
