查看: 974|回复: 1
戴尔Vostro_3900_3800_3902_A16主板官方bios 含自己主板的提取备份
发表于 2024-12-10 12:00:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
win11下可执行文件,不会使用。
|                 AMI Firmware Update Utility  v3.07.01.Dell                |
|      Copyright (C)2014 American Megatrends Inc. All Rights Reserved.      |
| Usage: AFUWINx64.EXE <ROM File Name> [Option 1] [Option 2]...             |
|           or                                                              |
|        AFUWINx64.EXE <Input or Output File Name> <Command>                |
|           or                                                              |
|        AFUWINx64.EXE <Command>                                            |
| Commands:        |
|         /O - Save current ROM image to file                               |
|         /U - Display ROM File's ROMID                                     |
|         /S - Refer to Options: /S                                         |
|         /D - Verification test of given ROM File without flashing BIOS.   |
|         /A - Refer to Options: /A                                         |
|       /OAD - Refer to Options: /OAD                                       |
| /CLNEVNLOG - Refer to Options: /CLNEVNLOG                                 |
| Options:        |
|      /CMD: - Send special command to BIOS. /CMD:{xxx}                     |
|     /MEUL: - Program ME Entire Firmware Block, which supports             |
|              Production.BIN and PreProduction.BIN files.                  |
|         /Q - Silent execution                                             |
|         /X - Don't Check ROM ID                                           |
|       /CAF - Compare ROM file's data with Systems is different or         |
|              not, if not then cancel related update.                      |
|         /S - Display current system's ROMID                               |
|       /JBC - Don't Check AC adapter and battery                           |
|  /HOLEOUT: - Save specific ROM Hole according to RomHole GUID.            |
|              NewRomHole1.BIN /HOLEOUT:GUID                                |
|        /SP - Preserve Setup setting.                                      |
|         /R - Preserve ALL SMBIOS structure during programming             |
|        /Rn - Preserve SMBIOS type N during programming(n=0-255)           |
|         /B - Program Boot Block                                           |
|         /P - Program Main BIOS                                            |
|         /N - Program NVRAM                                                |
|         /K - Program all non-critical blocks.                             |
|        /Kn - Program n'th non-critical block(n=0-15).                     |
|     /HOLE: - Update specific ROM Hole according to RomHole GUID.          |
|              NewRomHole1.BIN /HOLE:GUID                                   |
|         /L - Program all ROM Holes.                                       |
|        /Ln - Program n'th ROM Hole only(n=0-15).                          |
|      /ECUF - Update EC BIOS when newer version is detected.               |
|         /E - Program Embedded Controller Block                            |
|        /ME - Program ME Entire Firmware Block.                            |
|       /FDR - Flash Flash-Descriptor Region.                               |
|       /MER - Flash Entire ME Region.                                      |
|      /MEUF - Program ME Ignition Firmware Block.                          |
|         /A - Oem Activation file                                          |
|       /OAD - Delete Oem Activation key                                    |
| /CLNEVNLOG - Clear Event Log.                                             |
|   /CAPSULE - Override Secure Flash policy to Capsule                      |
|  /RECOVERY - Override Secure Flash policy to Recovery                     |
|        /EC - Program Embedded Controller Block. (Flash Type)              |
|    /REBOOT - Reboot after programming.                                    |
|  /SHUTDOWN - Shutdown after programming.                                  |
Vostro_3900_3800_3902_A16.7z
6.04 MB, 下载次数: 16, 下载积分: 下载分 -2 分
发表于 2025-2-22 20:35:16 | 只看该作者 �
非常需要。。。。。。。。。。。。。。。。。
