查看: 471|回复: 2
[MACBOOK]
Question: A1990 T2 Chip Replacement
发表于 2024-10-7 19:27:14 来自迅维网APP | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Does anyone know why the device can't be activated after replacing the T2 chip? I got the T2 chip from an A1989 device with a damaged CPU, and it didn't have an ID.
发表于 2024-10-8 13:00:59 | 只看该作者 �
1989's  T2 have an id also。You can use the sn of 1989 to check
发表于 2024-10-8 16:51:31 来自迅维网APP | 只看该作者 �
序列號沒有ID。 我已經檢查過了
