查看: 2289|回复: 4
re
发表于 2009-8-16 02:04:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 印度 来自 印度
thanks for reply the board does not say made in japan i saw one schematics on the tread vgn-s36gp but i think only for vip members.
发表于 2009-8-16 14:59:54 | 只看该作者 来自: 江苏苏州 来自 江苏苏州
I search for this schematic in our site, but does not find it. would you give an index to me?
I also search in my hard disk, there is no this schematic.
PS: There is no VIP on  our site now.
发表于 2009-8-16 16:22:50 | 只看该作者 来自: 印度 来自 印度
here is the link i search
http://www.chinafix.com.cn/viewt ... p;highlight=vgn-s36
thanks again for your kind support
发表于 2009-8-16 17:05:19 | 只看该作者 来自: 江苏苏州 来自 江苏苏州
There is an area for Professional repairman discuss. This need 威望 bigger than 30.
vgn-s36gp you found is not a schematic, it is a only an assembly and unasembly manual.
Sony's Original schematic is difficult to find. There is rare outside. Most Sony's schematic  you can find is OEM.
There is no any Secret, I copy it for you. After you  download it, please tell me. I will unpost the attach just for serving space.
attach removed
发表于 2009-8-16 18:34:04 | 只看该作者 来自: 印度 来自 印度
thanks you can remove the file much appreciate it.
