查看: 888|回复: 3
[LG]
LG 34GN73A-B
发表于 2022-11-19 21:06:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Hi to all.
I've got an LG 34GN73A-B monitor for repair. Is not starting well all the time (especially first time). backlight is on but no image ... just some fine lines at the bottom. Display is LM340WW2. Found on the display board 2 ANX1706 ic's. The right one is warming up to 60C degrees. left one is not warm. If I try multiple times is working just fine. After is powered there's no issues. Can you please advice me? Maybe someone else had this issue before. Thanks in advance.
发表于 2022-11-21 13:37:07 | 只看该作者 �
看不懂   啥情况
I need a schematic for LG 34GN73A-B. Thank you very much.  详情 回复 发表于 2022-11-25 10:21
发表于 2022-11-25 10:21:27 | 只看该作者 �
Yasus 发表于 2022-11-21 13:37
看不懂   啥情况
发表于 2022-11-30 00:01:25 | 只看该作者 �
LG 34GN73A-B的原理图好像很难找或是根本没有!
