查看: 3304|回复: 15
[维修资料]
日立硬盘修复工具 Feature Tool 2.15 - Change various ATA features.
头像被屏蔽
发表于 2021-11-3 19:06:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Feature Tool - Change various ATA features. Version 2.15 The Feature Tool is a DOS-bootable tool for changing various ATA features. It can modify certain features of our Deskstar and Travelstar high-performance ATA hard disk drives and supports 48-bit addressing for new, large-capacity drives.
Downloads
  • Feature Tool User's Guide Contains instructions for creating the bootable media under Windows and Linux, and information on how to use the program.
  • Diskette creator for Windows (1,692 K)
    Click here if having trouble creating bootable diskette
  • Binary diskette image (for non-Windows OS) (1,440 K)
  • CD image (2,578 K)
    Create a bootable CD for Windows, Linux and other operating systems (requires CD-RW drive and software).
Notes
  • Does not support Travelstar 8E, 10E, or C4Kxx series HDDs, or drives mounted in external enclosures.
  • Does not support the PC which loads Intel ICH9M chipset. HitachiGST are working to fix this situation.
Features in Version 2.13
  • Removed the function of acoustic management.
Changes ATA Drive Settings
  • Enable or disable the read-ahead or write cache.
  • Change the predefined capacity of the drive.
    - Used when BIOS limitation exists and the drive is not recognized.
  • Switch the Ultra DMA mode.
  • Change advanced power mode.
    - Switch between lowest and highest power consumption (maximum performance level).
  • Configure SATA interface.
    - Adjust maximum speed and enable/disable spread spectrum clocking.
    Warning! Switching your drive to support 3.0Gb/s, or enabling spread spectrum clocking and then using it, may render your drive unusable in a system that cannot support these functions. If in doubt, please contact your system manufacturer.
Shows Drive Temperature
头像被屏蔽
发表于 2021-11-3 19:07:36 | 只看该作者 �
解决日立硬盘修复工具 C1 增长快,噪声大。试试看呀
发表于 2021-11-21 12:06:33 来自迅维网APP | 只看该作者 �
正需要谢谢分享
发表于 2021-11-22 06:51:56 | 只看该作者 �
thanka very much
发表于 2021-11-22 11:05:13 | 只看该作者 �
收下先,有日立硬盘再来试看看, 谢谢分享。
发表于 2021-11-23 14:51:48 | 只看该作者 �
这个工具能修坏道清健康值不
发表于 2021-11-26 13:40:48 | 只看该作者 �
还不知道怎么,想下载,但是没分
发表于 2021-11-26 13:47:14 | 只看该作者 �
很想要,但是没钱,努力挣钱
发表于 2021-12-1 10:04:15 | 只看该作者 �
很想要,但是没钱,努力挣钱
发表于 2021-12-1 11:41:19 | 只看该作者 �
感谢分享! 努力赚钱
发表于 2021-12-1 13:49:38 | 只看该作者 �
谢谢分享谢谢。
发表于 2021-12-8 22:22:42 | 只看该作者 �
谢谢分享谢谢分享
发表于 2021-12-29 11:57:37 | 只看该作者 �
下载备用  谢谢分享
发表于 2021-12-30 10:39:48 | 只看该作者 �
写零工具,多谢。辛苦
发表于 2022-1-25 23:58:44 | 只看该作者 �
正需要谢谢分享
发表于 2022-1-29 14:34:40 | 只看该作者 �
感谢楼主分享~
