- 积分
- 43
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2020-3-24
- 精华
new generation processors are slightly different
This waveform seems normal to me.
The output waveform from the upper and lower mosfets is the pwm signal.
the coil then charges and the filters voltage. If you measure the output signal of the coil you will see a flat signal.
If a process goes in the system in new generation processors, pwm usually generates voltage to it.
sometimes there is a very low voltage in the coil. millivoltage (for cpu core)
Therefore, it is impossible to say a certain word just by looking at the form of the wave in the picture. |
