查看: 2614|回复: 6
HP 15 Quanta G75A System temperature 90D Error
发表于 2020-11-10 04:11:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Model: HP Pavilion Power 15-cb007nt
MB Code: Quanta G75A
The machine starts normally.
No liquid contact. Motherboard clean.
The system gives this error every time it boots up - System temperature 90D
Bios in another service was rewritten and sio was changed. But there is no result
A friend of mine encountered this problem
He changed it up to that chipset, unfortunately the result is 0
TM0 and TM1 (temperature sensors) I measured the signals. everything is normal.
There was another interesting problem with the machine.
I press the F2 button when it first starts. The hardware diagnostic menu opens
Then I exit menu and the system boots normally.
There was a possibility of gpu in my mind. And UMA enable motherboard
Board_ID0 R223 Move R223 (Pull down GND )
90D error no longer came after this operation.
Customer agreed to use in this case.
I hope there was some helpful information
Good day
Main Work Backup BIOS (8MB) + Quanta G75A Boardview
BIOS ID - 0836B
Backup BIOS Boardview.rar (5.19 MB, 下载次数: 3)
欢迎国际维修朋友 在论坛分享资料  发表于 2020-11-10 21:54
参与人数 2下载分 +10 +5 收起 理由
天意wx + 5 给愿意分享经验的人加分!
♂ㄒ♀ + 5 + 5
发表于 2020-11-10 09:21:11 | 只看该作者 �
国际友人?
H55
高加索地区的!  详情 回复 发表于 2020-11-10 23:24
回复 支持 2 反对 0
发表于 2020-11-10 08:56:57 来自迅维网APP | 只看该作者 �
Wonderful!good job! Seckill!
回复 支持 2 反对 0
发表于 2020-11-10 23:24:57 来自迅维网APP | 只看该作者 �
高加索地区的!
发表于 2020-11-10 22:30:08 来自迅维网APP | 只看该作者 �
wang7500 发表于 2020-11-10 09:31
是移动了电阻位置吗
对!改集显 的设定电阻!
发表于 2020-11-10 09:31:50 | 只看该作者 �
是移动了电阻位置吗
H55
对!改集显 的设定电阻!  详情 回复 发表于 2020-11-10 22:30
