查看: 3231|回复: 22
[维修资料]
Toshiba C660 LA-6842P short circuit
发表于 2020-6-24 05:22:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Model: Toshiba Satellite C660
Motherboard Code: LA-6842P Rev 1.0
Hello to everyone
Motherboard does not start. Current draw with adapter connect (0.045A -0.056A)
Battery is connected.  Only start led light active (low). But no start
I connectedit to the power supply and watched it with a thermal camera.
Heated part MOSFET (at the second MOS) P Channel 30V
Let's start measuring with a multimeter. Both MOSFET are intact ( M1 and M2 p channel)
No short circuit in +19V line 7.26mOhm (Normal)
Need to measure standby voltage coils
+3VALWP Coil – 8.57kOhm (Normal)
Need to measure standby voltage coils.
+5VALWP Coil – 14.10kOhm (Normal)
Then let's measure the value of the LDO line.
LDO +3.3V – 45.2Ohm (short circuit)
LDO +5.0V – 36.52kOhm (normal)
Let's separate the standby PWM on the motherboard (TPS51125A) Then let's measure the value of the LDO line.
There is still a short circuit in the LDO+3.3V line
Let's give 3V to the short circuit linefrom outside
Thermal camera comes to help
Heated part SIO ENE KB926QF
Let's take it off the motherboard SIO. And let's remeasure the LDO +3.3V line. No short circuit.
LDO+3.3 – 1.34mOhm (normal) Very Good.
I can't solder the standby PWM and replace new SIO KB926QF
Let's connect the motherboard to the power supply
Measure the standby voltage. Very good. The voltages are OK
Happy ending... Good day
参与人数 4下载分 +14 +9 收起 理由
kerokrrl + 2 + 2 给愿意分享经验的人加分!
天意wx + 5 给愿意分享经验的人加分!
便民电脑总汇 + 2 + 2 支持一下...外国同行。
新芯箱硬88 + 5 + 5 精品文章
发表于 2020-6-24 22:32:39 来自迅维网APP | 只看该作者 �
这个有点高深莫测了     看来是我学历太低了吧  不行到时饼哥弄个可@以在帖子里直接翻译的程序进来好了
多点外国人进来也是不错,也可以多多练一下英文久了就慢慢看会了,大不了百度翻译一下...  详情 回复 发表于 2020-6-25 11:02
回复 支持 2 反对 0
发表于 2020-6-24 23:10:49 来自迅维网APP | 只看该作者 �
文化有限,读不懂
发表于 2020-6-24 17:07:36 | 只看该作者 �
英文啊 有点看不懂
发表于 2020-6-24 12:01:06 | 只看该作者 �
So good,
发表于 2020-6-24 08:11:35 来自迅维网APP | 只看该作者 �
国际友人,全是英文,是换ec好的嘛
发表于 2020-6-24 08:42:34 来自迅维网APP | 只看该作者 �
LDO -Ec short!  Good job!
发表于 2020-6-24 10:33:00 | 只看该作者 �
什么啊,英文看不懂啊
发表于 2020-6-24 11:26:26 | 只看该作者 �
线性3.3V短路  排查 EC损坏 更换 故障解决
发表于 2020-6-24 23:11:05 来自迅维网APP | 只看该作者 �
good
发表于 2020-6-25 08:24:46 来自迅维网APP | 只看该作者 �
em....真心看不懂哎,对了国外人气较高的维修论坛叫啥啊?有空了我要多逛逛学习学习,
发表于 2020-6-25 08:46:29 来自迅维网APP | 只看该作者 �
3V LDO短路,最后是EC问题 这问题还是比较常见的
发表于 2020-6-25 09:08:55 | 只看该作者 �
very good!!国外都知道迅维了
发表于 2020-6-25 11:02:12 | 只看该作者 �
发表于 2020-6-25 11:07:19 来自迅维网APP | 只看该作者 �
这位是外大袖啊,见识了大神。
发表于 2020-6-25 14:53:41 | 只看该作者 �
看不懂系列。。。。。。。。。。。。。。。。。。。。。。。。。。。。。
发表于 2020-6-25 17:15:01 来自迅维网APP | 只看该作者 �
设备很先进,我一般用手。谢谢分享。
发表于 2020-6-25 17:17:00 来自迅维网APP | 只看该作者 �
我们这边一般用二极管档位测试,红表笔接地,黑表笔量测试点。
发表于 2020-6-25 20:24:14 来自迅维网APP | 只看该作者 �
pyjincheng
这个有点高深莫测了     看来是我学历太低了吧  不行到时饼哥弄个可@以在帖子里直接翻译的程序进来好了@月饼
发表于 2020-6-26 07:05:07 来自迅维网APP | 只看该作者 �
Thank you for sharing!
