查看: 2181|回复: 15
[维修资料]
HP DV7 no standby pwm voltage
发表于 2020-5-3 21:52:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Model: HP Pavilion DV7
MotherboardCode: Quanta UT3 DIS Only
Hello to everyone
A laptop came to my service. Motherboard does not start. I connectedit to the power supply.
I connectedit to the power supply . Standby mode 0.004A . I started measuring.
1. Measuring VIN +19V –OK. Both mosfetswere open. +19 voltages were shared on the motherboard
2. Then I measured the values of the standbypwm coils (PL8 and PL9)
PL8 > +5VPCU = 2.3K and PL9 > +3VPCU =3.1K (an average value) no short circuit.
3.  I reconnected the power supply and imeasured the supply voltages.
PL8 > 0.507mV PL9 > 27.3mV ( this is not normal )
4.  Standby voltage controls on the motherboard PU2 (RT8206B)
Need to die the main voltage coming to the chip first. Measuring RT8206B 6PIN. Low voltage passes across the resistor to the other side. PR22 1R resistor SMD Code 1R0 . Measured the resistance (PR22 – 137K) this is not normal.
I measured the LDO voltage (RT8206B PIN7). There is also strangeness here. (Normal voltage LDO +5.0V)
Replace resistance add 2R2 (2.2R). +19 voltage fully input.
Connected the power supply. there is also strangeness here. standby mode 0.049A . There is a short circuit
I examined with thermal camera and the heated PWM RT8206B.  Changed PWM.
Connected the power supply everything is normal standby mode 0.007A . Voltage normal at standby coils
And the expected moment has come
Happy Ending...
Note: The problem with this motherboard is due to low quality adapters.
such products often damage laptops. I met often
Good day...
参与人数 6下载分 +17 +23 收起 理由
348221773 + 5 + 5 给愿意分享经验的人加分!
wideman + 1 清晰明瞭
趁买内 + 5 + 5 外国兄弟发的贴支持一下。虽然不是大毛病
DBJBW + 2 + 2 给愿意分享经验的人加分!
天意wx + 5 给愿意分享经验的人加分!
H55 + 5 + 5 精品文章
发表于 2020-5-4 20:21:23 | 只看该作者 �
Happy Ending...
i am form Azerbaijan
参与人数 1下载分 +5 +5 收起 理由
H55 + 5 + 5 给愿意分享经验的人加分!
发表于 2020-5-3 22:04:57 | 只看该作者 �
Happy Ending...
RT8206 报废! 干掉
激动人心的时刻 来了,亮鸡!!  完美收工。。
你是那里的。。美国的?? where are you from ? USA?   Young Boy ?
i am form Azerbaijan  详情 回复 发表于 2020-5-4 20:21
发表于 2020-5-3 22:08:38 | 只看该作者 �
欢迎外国的维修朋友 欢迎在论坛分享相关维修案列
发表于 2020-5-3 22:12:21 | 只看该作者 �
咋一股大碴子味儿?
发表于 2020-5-3 22:26:48 | 只看该作者 �
全文没用翻译看的。全部靠自己三脚猫英语水平看完的。理解个90%。待机芯片烧了。导致PR22 保险也烧了。就这样。你就给你加分了
发表于 2020-5-3 22:35:51 | 只看该作者 �
发表于 2020-5-3 23:25:35 来自迅维网APP | 只看该作者 �
cool work, and glad to see . so, welcome to post more.
发表于 2020-5-4 09:37:04 | 只看该作者 �
学习了,谢谢,东西真全
发表于 2020-5-6 22:15:41 | 只看该作者 �
欢迎外国的维修朋友,有点看不懂
发表于 2020-5-7 01:15:36 来自迅维网APP | 只看该作者 �
英语太差,看不懂
发表于 2020-5-7 09:08:54 | 只看该作者 �
欢迎外国朋友。
发表于 2020-5-7 11:02:31 | 只看该作者 �
是一位国际友人,写的很有水准
发表于 2020-5-7 21:21:01 来自迅维网APP | 只看该作者 �
欢迎国外友人分享!!!!
发表于 2020-5-7 23:40:38 来自迅维网APP | 只看该作者 �
技术无国界。
分析得详细。
发表于 2020-5-8 01:37:24 来自迅维网APP | 只看该作者 �
这外国朋友的装备还是不错的,就是维修水平比起中国人来说还是有很大距离的!要不说中国人了不起,做技术全球除了中国人日本人基本上没谁了。
