查看: 1686|回复: 1
[显卡维修]
ATI9550 128MB 显卡花屏R3测试结果,请大家指点。。
发表于 2009-7-18 10:33:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
ATI9550  128MB 显卡花
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 12 14 15 16 17 18 19 20 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
    failing bit : MDB0 0 1 2 3 4 5 6 7 ...
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
    failing bit : MDB0 7 12 14 15 16 17 18 19 ...
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.8 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.8 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.8 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.8 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.8 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.8 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.8 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.8 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.8 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.8 not found
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.8 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.8 not found
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
     error : R051A.9 not found
     error : R052A.9 not found
     error : R053A.9 not found
     error : R055A.9 not found
     error : R061A.9 not found
     error : R062A.9 not found
     error : R063A.9 not found
     error : R065A.9 not found
     error : R071A.9 not found
     error : R072A.9 not found
     error : R073A.9 not found
     error : R075A.9 not found
Failure detected.
屏R3测试结果,请大家指点。。
发表于 2009-7-18 12:02:44 | 只看该作者 �
先测U3  U5  U9 U10你的卡很有可能是B通道损坏
