查看: 1495|回复: 6
Error (0x000000a5)
发表于 2019-8-14 15:51:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Error (0x000000a5)
Solution:-
1:- I tried to change hdd and ram but problem was same
2:- next I tried to update bios with clean me region but problem same
3:- I tried another processor but always same problem
Then I study on error and get solution the solution was
Insert bootable pendrive/cd and go into repair option and choose command prompt
On that choose
First C:\bootrec/fixMbr
2nd C:\bootrec/FixBoot
3rd C:\bootrec/RebuildBcd
And then C:\Exit from their and restart pc problem was solve..
发表于 2019-8-14 15:54:50 | 只看该作者 �
引导问题,解决就好
发表于 2019-8-14 16:00:22 | 只看该作者 �
赞赞赞赞赞赞赞赞赞赞
发表于 2019-8-14 16:00:28 | 只看该作者 �
一个引导问题。被楼主搞得那么复杂。
发表于 2019-8-14 16:38:40 | 只看该作者 �
where are you from? boy
发表于 2019-8-14 19:36:31 | 只看该作者 �
进pe可以修复吧
发表于 2019-8-14 22:13:14 | 只看该作者 �
