查看: 943|回复: 3
[已解决]
laptop turn off within a few seconds if ram inserted in dimm0
发表于 2018-6-23 01:49:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 尼泊尔 来自 尼泊尔
Problem: Laptop works on only one dimm1 slot, laptop turn off within a few seconds if ram inserted in dimm0
Laptop: Dell 14r-5420 R08
Board number: DA0R08MB6E2
Counterparts was "Customers told that laptop has no issue as it is condition but  if they need to increase RAM on another slot, laptop shut down immediately....PCH need to be replaced ." "It's broken? How much you charge for that?
I told customer “how you come to know that PCH is problem?   ....reply was_ he visited repair shop and they replaced RAM, checked for corrosion even use a Multi meter to diagnose... then recommended, only go to there, where BGA Machine is Available.
          Now I received the Laptop
Get the machine, watched the appearance and inspections of the motherboard... thanks god... nowhere was touched.
Now come to the Point
dell 5420 _r08 dimm problem.pdf
484.04 KB, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
Case Study
H55
给你翻译哈子:内存只能插DIMM1口,如果插在DIM0等几秒就掉电老!后面的懒得翻译了,我就说个大概, 客户自己升级内存条只要插在另外的口就掉电,客户说桥报废到其他维修店看过了,这个老外拆开一看 主板还是处...  发表于 2018-6-23 20:33
参与人数 1下载分 +5 +5 收起 理由
天意wx + 5 + 5 鼓励发帖
发表于 2018-6-23 20:17:52 | 只看该作者 来自: 河北石家庄 来自 河北石家庄
是没有写完?   欢迎外国维修朋友在论坛发帖
发表于 2018-6-23 22:46:30 | 只看该作者 来自: 尼泊尔 来自 尼泊尔
thank you very much ... need your best guidence
