查看: 2621|回复: 1
上一主题 下一主题
lenovo w540 lkm-1 ws mb 12291-2 no boot
发表于 2017-6-13 19:33:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Lenovo w540 lkm-1 ws mb 12291-2  not boot.. voltage is good.. what to do?
发表于 2018-7-15 21:52:25 | 只看该作者 �
flash bios 4 chips at this site all files 2 of them below vga card
发表于 2020-4-12 07:20:45 �
Use pq56 to push + 15V to the past and apply + 3V voltage to pq23 to generate starting voltage.
be careful:!! The 33.8mhz of this board will not vibrate when it is in standby mode. The BIOS can be powered on as long as it has 2V voltage
In addition, Lenovo's machine must use the original power adapter, otherwise it will not charge
支持 反对
