查看: 1919|回复: 3
[显卡维修]
镭风X550花屏 R3测试结果,帮我看看哪个颗粒坏了
发表于 2010-8-25 15:02:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
  [1] Fill
Failing bits in test [1] Fill
  errcount: 2
  MDA0: 12
Failing bits in test [2] Data line toggle (GUI)
  errcount: 150075
  MDA0: 12
  MDB0: 60
Failing bits in test [3] RW column (GUI)
  errcount: 1764
  MDA0: 12
Failing bits in test [4] RW page (GUI)
  errcount: 117124
  MDA0: 12
  MDB0: 60
Failing bits in test [5] RW channel (GUI)
  errcount: 6157
  MDA0: 12
  MDB0: 60
Failing bits in test [6] Data mask
  errcount: 1895976
  MDA0: 12
  MDB0: 60
Failing bits in test [7] Macro + Micro8x2 tiling read
  errcount: 165876
  MDA0: 12
Failing bits in test [8] Macro + Micro4x4 tiling write
  errcount: 214808
  MDA0: 12
Failing bits in test [9] Byte swap macro+micro8x2 read
  errcount: 2640809
  MDA0: 12
  MDB0: 60
Failing bits in test [10] Byte swap macro+micro4x4 write
  errcount: 3212632
  MDA0: 12
  MDB0: 60
Failing bits in test [11] Marco+Micro8x2 alignment write
  errcount: 972
  MDA0: 12
Failing bits in test [12] Macro+Micro4x4 alignment read
  errcount: 1797
  MDA0: 12
TEST RESULT SUMMARY:
RV370/M22 A12b (0x5b63) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 12
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDA0 12 MDB0 60
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
Failure detected.
排列图(双面,每面4颗)
                                U32 (背面U36)         U35(背面U31)
                                      X550                        U34(背面U30)
        U33(背面U29)
这卡DOS下花屏,装驱动进系统黑屏,核心加悍过无效,加焊U33,U35,U29,无效
已解决,把显存颗粒全部加焊一下,亮机正常,进系统正常,谢谢乐天
发表于 2010-8-25 19:26:40 | 只看该作者 �
先查U32  U33
发表于 2010-8-26 14:11:48 | 只看该作者 �
正面的A1 B2  应该就是正面的 U33 U32
难道正面背面的U**标号一样吗?
发表于 2010-8-26 21:05:04 | 只看该作者 �
DATA线不良了,用笔尖应该能挑开个人经验而已,别人不一定能查得到
