查看: 1960|回复: 5
[显卡维修]
盈通 9550花屏
发表于 2010-7-3 19:13:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
测试结果
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
Failing bits in test [1] Fill
  errcount: 2386622
  MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Failing bits in test [2] Data line toggle (GUI)
  errcount: 1845355
Failing bits in test [3] RW page (GUI)
  errcount: 1430850
Failing bits in test [4] RW channel (GUI)
  errcount: 2947327
Failing bits in test [5] Data mask
  errcount: 2360241
Failing bits in test [6] Macro + Micro8x2 tiling read
  errcount: 404022
Failing bits in test [7] Byte swap macro+micro8x2 read
  errcount: 34415973
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.8 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.8 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.8 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.8 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.8 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.8 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.8 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.8 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.8 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.8 not found
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.8 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.8 not found
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
     error : R051A.9 not found
     error : R052A.9 not found
     error : R053A.9 not found
     error : R055A.9 not found
     error : R061A.9 not found
     error : R062A.9 not found
     error : R063A.9 not found
     error : R065A.9 not found
     error : R071A.9 not found
     error : R072A.9 not found
     error : R073A.9 not found
     error : R075A.9 not found
Failure detected.
双面 共8个颗粒的显存
背面的图片
发表于 2010-7-3 19:14:31 | 只看该作者 �
不会看测试结果   找如何看测试结果 也找不到 555
还是给指点下吧
感觉 咋像GPU虚焊呢
发表于 2010-7-3 23:16:58 | 只看该作者 �
全报错测一下显存供电对不对
发表于 2010-7-4 08:48:42 | 只看该作者 �
哦  好的 我先测测
发表于 2010-7-4 09:27:27 | 只看该作者 �
测量 1 3脚 2.73V
49脚 1.36
这也正常呀
和测试的主板 和 R3的版本有关系吗 这种情况
发表于 2010-7-4 10:47:04 | 只看该作者 �
学习中·期待早点解决·
