- 积分
- 2
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2023-7-4
- 精华
9#
发表于 2024-11-12 18:27:50
只看该作者
I'm fighting with one right now... these are my discoveris that it might help
first, there are two types of this machine, vPro with 256M bios chip and non-vPro with 128M Bios
Lenovo's update has two files 37MB each, R15ET ** W and R15ET** P , I don't know which is which or the difference but according to my previously working backup vPro is W
secondly, This mchine will not trigger with a bios that contains a lower version of intel management engine if it was working on a higher version before !
for example, if you take a working bios backup of your working machine and it has ME 14.1.53.1649 then update your system to the latest released ME 14.1.74.2355, your old backup won't trigger anymore!
it will trigger only if you inject the new ME in your backup, that's what I did and the problems start (m.2 doesn't work anymore) Although the new ME was taken from lenovo's update !
even the ME update contains two files Consumer_LP & Corporate_LP and according to my backup my vPro uses Corp_LP
I made a dump from scrach based on the latest lenovo update Bios v1.42 & EC v1.12 + ME 14.1.74.2355_Corp_LP, flashed that + EC flash but still no m.2 note that if you remove the drive an error message appears that m.2 is not detected..
Injected 14.1.74.2355 or 14.1.70.2228 in the original working backup, still no m.2
I didn't figure it out yet, why it won't start with the original backup and original ME, and why an official bios with updated ME won't detect m.2 ??
I'll share all the files it might help.. (all vPro 256M Bios version)
Original backup of the machine + original ME 14.1.53.1649 tested ok m.2 ok (wont trigger anymore after ME update)
My Backup LAR-1 MB 18834-1N.rar
(11.09 MB, 下载次数: 57)
