- 积分
- 6
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2010-11-22
- 精华
五馬倒六羊 发表于 2013-7-31 16:23
三个80欧应该是红绿蓝,两个5V 应该是行场,随便找个地或者把几个地拧在一起,这应该就有图像了,至于颜色就 ...
HSYNC CRT horizontal synchronisation output.
VSYNC CRT vertical synchronisation output.
DDCCLK Display Data Channel Clock. Used as clock signal to/from monitors with DDC interface.
DDCDAT Display Data Channel Data. Used as data signal to/from monitors with DDC interface.
RED Analog output carrying the red colour signal to the CRT. For 75 O cable impedance.
GREEN Analog output carrying the green colour signal to the CRT. For 75 O cable impedance.
BLUE Analog output carrying the blue colour signal to the CRT. For 75 O cable impedance.
DIG-GND Ground reference for HSYNC and VSYNC.
ANA-GND Ground reference for RED, GREEN, and BLUE.
根据所说应该是红蓝绿.但有5V的不最试,怕把显示器点冒烟了. |
