查看: 5705|回复: 8
围观,希捷160g Read Ver RetrysRead Ver Failure!怎么解决?
发表于 2012-11-12 00:08:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
maxtor 160g 10代   提示错误怎么修??
1024k x 16 DRAM
NHAWK - 1_Disk    S-LE   11-14-07_16:30
Buzz HM SFI
(P)SATA Reset
Failed sys sect. write! Nwt Er 33 RdWr 13680.00.0003
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 13680.00.0003
如何做通病修复和只读修复
发表于 2012-11-12 15:20:09 | 只看该作者 �
只读故障,清一下G表和SMART表看看,不行就做F级吧。
Reset 1024k x 16 DRAM NHAWK - 1_Disk S-LE 11-14-07_16:30 Buzz HM SFI ! (P)SATA Reset Failed sys sect. write! Nwt Er 33 RdWr 13680.00.0003 Read Ver Retrys Read Ver Retrys Read Ver  详情 回复 发表于 2012-11-12 17:09
G表和SMART 清不了。提示错误。 怎么做f级。。麻烦罗老师指教  详情 回复 发表于 2012-11-12 16:39
发表于 2012-11-12 16:39:15 | 只看该作者 �
发表于 2012-11-12 17:09:28 | 只看该作者 �
Reset
1024k x 16 DRAM
Buzz HM SFI
(P)SATA Reset
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
T>
CE Log ErrCode=0  LBA=0  Type=aFailed sys sect. write! Nwt Er 33 RdWr 13680.00.005a
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 13680.00.005a
Failed sys sect. write! Nwt Er 33 RdWr 13680.00.0006
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 13680.00.0006
Initializing SMART SectorsFailed sys sect. write! Nwt Er 33 RdWr 13680.00.0006
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 13680.00.0002
FAIL
1>l
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
FAIL
1>(
1>/
T>/
T>i1,1,22
Command Inactive - No VALID Cert Code Detected
T>
发表于 2012-11-13 08:30:22 | 只看该作者 �
清G表是   i4,1,22 ,先装载CERT
你说的做f级是什么意思??  详情 回复 发表于 2012-11-13 11:39
试过了。真的不行的。这个硬盘拿在手里感觉转的很快,比其他的要快。。  详情 回复 发表于 2012-11-13 11:36
发表于 2012-11-13 11:36:27 | 只看该作者 �
发表于 2012-11-13 11:39:17 | 只看该作者 �
你说的做f级是什么意思??
发表于 2012-11-21 22:22:23 | 只看该作者 �
F自校准吧
发表于 2012-11-22 01:36:03 | 只看该作者 �
具体怎么做啊??n2,,22??
