查看: 1733|回复: 2
问个问题,CM6802的小板,输入15V电压,PFC和PW输出为0
发表于 2021-10-1 10:22:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
CM6802的小板,输入15V电压,PFC和PW输出为0,怀疑是小板子的,芯片坏了,看了下芯片是,hiCM6802的,现在手里,只有CM6800了,这个6800能替换,6802么
发表于 2021-10-1 19:33:32 | 只看该作者 �
‹in     to     pin     compatible     with     CM6800,CM6800A,     ML4800 and FAN4800. ‹23V Bi-CMOS process. ‹Designed for EPA/80++ efficiency. ‹CM6802A/B  :  Selectable  Boost  output  from  380V  to  300V    during light load. ‹CM6802AH/BH:  Selectable  Boost  output  from  380V  to  342V    during light load.
发表于 2021-10-1 19:36:50 | 只看该作者 �
